  IC options for supercharger
IC options for supercharger by frockfiero
Started on: 11-20-2022 08:17 PM
Replies: 5 (382 views)
Last post by: Fie Ro on 11-22-2022 05:52 PM
frockfiero
Report this Post11-20-2022 08:17 PM Click Here to See the Profile for frockfieroSend a Private Message to frockfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Buttoning up my engine and looking to add an IC to my SC build but I'm shy on the 1200 price tag for the ZZP IC. Is this the only option? can I run the same IC that I see on turbo setups?
Intercooler I'm Looking at
Current Build:
Stage 3 Intense Heads
Forge pistons
ZZP rockers
OE-R Comp Rollers
2.5 Pulley
345 E85 Fuel pump
cam-a-lot
Total ratings: 99
Report this Post11-20-2022 08:31 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
would help if you specify the engine
La fiera
Report this Post11-20-2022 09:11 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Obviously it might be a 3.8L V6 Supercharged.
claude dalpe
Report this Post11-20-2022 09:21 PM Click Here to See the Profile for claude dalpeSend a Private Message to claude dalpeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Frockfiero,
You must have an intercooler between the supercharge and your intake and not at the entrance of the supercharger
Because the supercharge is the one that produces the heat, same thing as with a turbo, the intercooler is installed after the turbo and not before.
frockfiero
Report this Post11-20-2022 09:39 PM Click Here to See the Profile for frockfieroSend a Private Message to frockfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Frockfiero,
This makes sense now, I needed it spelled out I guess.
Fie Ro
Total ratings: 132
Report this Post11-22-2022 05:52 PM Click Here to See the Profile for Fie RoSend a Private Message to Fie RoEdit/Delete MessageReply w/QuoteDirect Link to This Post
You might find a used set for less $ but still there's a lot of work in the install. Need to fab 2 IC coolant lines to the front and room for the radiator. Custom fuelrails.
With the rather small 2.5 pulley you need intercooling and likely larger injectors.
