It sounds like your mechanic may not be retracting the rear caliper pistons properly. The best way to do that is by using the adjusting screw at the back. Some have done it by twisting the piston from the inside end but I've never had any luck with that . You take off the nut then adjustment lever, seals and turn the shaft by hand and the piston will retract into the bore. If you try to use the brake piston compression tool you will damage the caliper internally. IMO, the Fiero rear breaking system leaves quite a bit to be desired but you can get it to work with a bit of fiddling
