| quote | Originally posted by theogre:
Shifter can have crap causing problems... quick check pull out ashtrays and use flashlight.
Interlock to steering can bind etc. See my Cave, Auto Shifter
Iffy NNS on trans end maybe have problems or bad. See my Cave, Neutral Safety Switch
Thanks sir, I'll take it apart this weekend. It's held together by basically nothing, so that's no issue, lol
The shifter moves no problem, but it's clearly not always "grabbing" correctly all the time. I'll use it 10 times and this may occur only once. I was hoping there was a known wear issue, but I'll get it figured out.
I've already pulled the T-Handle and depressed the plunger by hand. Same thing. Intermittent.
[This message has been edited by Brivander (edited 01-19-2022).]
