I have an '88. I don't know if my question applies to other years..... I'd like to replace the heater core hose that tees into the rear passenger side coolant tube. Seems easy enough, but this hose isn't just a short hose with hose clamps on each end. The connection at the coolant pipe is a hose clamp. At the other end of this short hose it's a compression fitting like you'd see on high pressure hoses; such as AC lines or power steering hoses. What's the best way to replace this hose?
I'm guessing you just cut the compression fitting off and slip a hose over the hard pipe and use hose clamp(s). Is this what others have done? Thanks.
Stanton
'88 Formula, red on gray
