Welcome to the forum. On the front hood have an assistant pull the release cable as hard as he or she can and while holding it you try to lift the hood. There is a spring in the center of the cowl that makes the hood jump up an inch or so. If that spring is weak or missing the hood will not lift from the latch so when you release the cable the hood is still locked.
Rear is similar. Have assistant turn key or pull cable and hold in position while you lift the deck lid. If the deck lid torsion bars have been removed or broken the lid will not spring up from the latch. Ask me how I know. If you have a spoiler like I do and no torsion bars it will feel like you're lifting 30 lbs or more.
Let us know if this helps.
Spoon
"Kilgore Trout once wrote a short story which was a dialogue between two pieces of yeast. They were discussing the possible purposes of life as they ate sugar and suffocated in their own excrement. Because of their limited intelligence, they never came close to guessing that they were making champagne." - Kurt Vonnegut [This message has been edited by Spoon (edited 10-05-2021).]
