Hi all,
I have recently noticed that my clutch has been slipping, I wanted to ask a few questions before I start planning to replace it.
First off, I have an 86 SE - v6 with the 5 speed Getrag, 55000 miles. My clutch has always engaged at the top of the pedal, since I bought the car a year and a half ago. Recently I have found that in top gear under full throttle the clutch will slip. It does not slip during normal driving. I learned how to drive manual in this car so it is somewhat likely that the clutch is worn out.
1. Is there anything else I should check before replacing the clutch? (Bleed, flush the system, etc?)
2. I have found that leaking fluids can cause the clutch to slip as well. I have a transmission fluid leak - I’m not sure where it’s coming from. I have already replaced the axle seals. What should I check to pinpoint the leak?
3. What else should I look at replacing with the clutch? I know that my differential bearings are worn, is it worth tearing apart my transmission to replace them while I have the transmission out?
1986 Fiero SE. V6 5 speed.
[This message has been edited by willyt (edited 10-05-2021).]
