Careful... "Amp rating" for given wire is Gauge/Diameter
And Length and other specs.
That why most charts say amps
per Hundred Feet etc.
vs you have maybe 3 feet max from Alt to + box under C500.
Sim for battery cables that often are only 1 to 4 feet each in most vehicles. Is why most OE battery cables are 4ga or similar metric size stranded wire for cars and other light vehicles (Light Vehicles are mostly < ~ 10,000lb GVWR) but bigger vehicle can have same alt out and battery cables.
If you have large power eating things... run them to + box, maybe get a heavier + box or even run off the alt out terminal.
Note that Amp Rating for Alt's is nearly always Peak Power.
See my Cave,
Watt Story------------------
