  F23/3800 SC- Consensus on clutch ?
F23/3800 SC- Consensus on clutch ? by cam-a-lot
Started on: 06-13-2021 07:22 PM
Replies: 4 (304 views)
Last post by: Will on 06-19-2021 08:15 AM
cam-a-lot
Total ratings: 99
Report this Post06-13-2021 07:22 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello folks
Any input on what brand of clutch you have used for this combo? I believe I need to get a spacer to prevent the HTOB from over extending, but what has been a successful clutch for this trans/engine combo?
I have been running a Spec 3 behind my 282 Getrag/3800 SC for a number of years and have been happy with it.
Any reason to switch? I believe my fywheel is fine- don't seem to have any issues with it
thanks
jb1
Report this Post06-13-2021 08:27 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Using 3+ on a current build.. haven't got to.point of installing flywheel etc.
Total ratings: 237
Report this Post06-14-2021 01:05 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some older clutches have slight interference with the F23 bellhousing... so check that out. Otherwise, I haven't heard of a reason you wouldn't be able to keep running the same clutch.
cam-a-lot
Total ratings: 99
Report this Post06-18-2021 10:13 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any other input on this?
Total ratings: 237
Report this Post06-19-2021 08:15 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do a test fit of the trans, torque the bellhousing bolts, then roll the engine over by hand. If you have problems, then you have the pressure plate cover/bellhousing interference issue.
I assume you've researched the F23 swap and are comfortable with all the other needs.
