  Electrical problem - melted wire
Electrical problem - melted wire by trivet
Started on: 04-20-2021 12:53 PM
Replies: 3 (240 views)
Last post by: reinhart on 04-26-2021 04:25 AM
trivet
Report this Post04-20-2021 12:53 PM Click Here to See the Profile for trivetSend a Private Message to trivetEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 87 GT (stock 2.8) decided not to start, I had power and fuel, but would not turn over. After a few attempts I could smell smoke, and this is what I found:
No idea if this is the problem or just a symptom - can I just replace the wire?
What else should I be looking for?
Any help is appreciated - thank you!
[This message has been edited by trivet (edited 04-20-2021).]
Xenoblast
Report this Post04-20-2021 01:33 PM Click Here to See the Profile for XenoblastSend a Private Message to XenoblastEdit/Delete MessageReply w/QuoteDirect Link to This Post
That wire doesnt look like it melted, more teared off. I think that wire is for the ecm, but I could be wrong. One thing I would check, is if your tachometer moves while cranking. if not, its probably the icm that failed which i experience like a week ago
Total ratings: 568
Report this Post04-20-2021 06:31 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like a fusible link cooked off but pictures are poorly taken so can't tell.
Could be the problem or likely just a symptom of shorting something else.
Several circuits have no fuse in the fuse box or anywhere but a fusible link.
See my Cave, Fuse Links notes and Wire Service
reinhart
Report this Post04-26-2021 04:25 AM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
That wire is the one from the pos battery terminal to the junction box? I don't beleive that one has a fusible link but a of the ones coming out of the junction box do so one of those links should have been the one to short. Did someone replace a blown fusible link with a wire or something? That's the only reason I could think this would happen
