Heya folks!
It's oil pan replacement time, and I am trying to figure out how best to access the forward bolts on the front engine mounting bracket. There's lots of good information out on the Internets about the later 2.8L models, but this is a 1984 2.5L, and I haven't found much in the way of advice on this job's specifics. Even the Haynes manual kind of glossed over this bit!
How do you actually get at these bolts? Coming in front the wheel well doesn't seem feasible with the bolts facing forwards, and there's a metal plate below the compressor bracket. Are you supposed to remove the entire compressor bracket as well? Not that it would help this particular issue since both brackets are bolted to the block... I'm stuck here; any advice is greatly appreciated.
Thank you very much!
Exhibit A) The offending bolts (and the yucky oil pan not long for this world)
Exhibit B) The bolts I'm mostly sure I'm looking at. Interestingly, Autozone's oil pan removal diagrams don't even seem accurate. This is their compressor diagram.
Total unrelated aside, but I'm fairly certain I'm not the first person to do this job, despite the pan's old appearance. Someone drilled out a couple points on the edge of the flange above the bracket to give their RTV more of a place to adhere. Why they did this, I have no idea, but the pan is now hanging on those points. I'll be glad to have the replacement installed.
