Nothing new there and been available for 40+ years and fit most engines.
This should have direction to use some type of "sealer"/"glue" to install them.
Otherwise can leak oil between sleeve and balancer.
If you buy a timing cover gasket set w/ a sleeve often comes w/ correct "glue" but buy only the sleeve may say nothing about this.
When you drive/press the sleeve, wood or plastic to spread impact/force and hit that in the middle so doesn't tilt or easy to wreck them.
GM etc has plastic tools to install for this reason.
Installing new seals need thin coat of Super 300 and related on outside to stop small scratches on metal leaking oil.
