⚠️ Warning: You're first step is have pulling Heater Blower and used small camera or mirrors to check trash in the AC/Heater box.
If mice etc got crap in AC mode motors and you fool w/ the buttons then very likely you burn the control board and/or fuse.
If crap is in blower resistor pack then can easily have a Fire. see
https://www.fiero.nl/forum/Forum2/HTML/141959.html and may others.
Testing mode motors etc...
See my Cave,
Heat & ACRadio...
Can be dead for several reasons maybe making a noise and do little or nothing.
OE Radio uses 2 fuses. Bat fuse is known to blow. See my Cave,
Sneak PathFirst Pull all fuses at check for 0Ω
Old fuses may Look "OK" and still be "blown" for very small cracks you can't see.
30+ year old "radios" die of old age alone w/ crack solder joints, bad caps, and more. Many "newer" radios from GM to replace/upgrade them are starting same problems because most are 20+ years old.
