  fuel injector question
fuel injector question by 86fierorestoproject
Started on: 03-29-2021 01:09 AM
Replies: 2 (89 views)
Last post by: 86fierorestoproject on 03-29-2021 02:42 AM
86fierorestoproject
Report this Post03-29-2021 01:09 AM Click Here to See the Profile for 86fierorestoprojectSend a Private Message to 86fierorestoprojectEdit/Delete MessageReply w/QuoteDirect Link to This Post
i have an 86 SE 2m6 that i'm changing 1 fuel injector on, and i know that the stock injectors are 15lbs, but the new one is 19lbs, and im only changing one injector. will this flood the combustion chamber? or will it just burn rich as hell? mods: oversized camshaft, cat delete.
Total ratings: 567
Report this Post03-29-2021 02:20 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can't replace 1 injector w/ a bigger unit.
All needs to be same "size" or will have problems.
ECM can/will try to "fix" 1 cyl running rich by leaning out most to everything else.
Running lean has a nasty habit of Destroying the engine.
86fierorestoproject
Report this Post03-29-2021 02:42 AM Click Here to See the Profile for 86fierorestoprojectSend a Private Message to 86fierorestoprojectEdit/Delete MessageReply w/QuoteDirect Link to This Post
okay, i will just blow compressed air through the old one, and see if i can get that to work until the other injectors arrive. thanks ogre!
