  What do I use?
What do I use? by str8maxn
Started on: 03-23-2021 04:31 PM
Replies: 7 (246 views)
Last post by: PatrickTRoof on 03-30-2021 05:25 PM
str8maxn
Report this Post03-23-2021 04:31 PM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello All,
I'm in the process of changing the color of my interior to black. I'd like to upholster the top half of the door panel vs. paint.
I'll be using a black leather like vinyl but I'd like to fill in the seam on the door panel. It would make this job a bit easier.
Any suggestions?
PatrickTRoof
Report this Post03-25-2021 03:09 PM Click Here to See the Profile for PatrickTRoofSend a Private Message to PatrickTRoofEdit/Delete MessageReply w/QuoteDirect Link to This Post
Foam, maybe? Do you have a junk door card you can practice on?
str8maxn
Report this Post03-25-2021 03:43 PM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't have one to practice . But while at the upholstery shop , I spoke to the owner and he suggested using 1/4 form and cover all the door panel with it.
My plan was to upholster directly over the original door panel.
Tha Driver
Total ratings: 204
Report this Post03-25-2021 03:58 PM Click Here to See the Profile for Tha DriverClick Here to visit Tha Driver's HomePageSend a Private Message to Tha DriverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe glue in a wooden dowel to support the foam & keep it from sinking in.
Might need to grind the outer surface flat... (at least that would be ideal if you can find the right size dowel).
~ Paul
aka "Tha Driver"
[This message has been edited by Tha Driver (edited 03-25-2021).]
PatrickTRoof
Report this Post03-25-2021 03:59 PM Click Here to See the Profile for PatrickTRoofSend a Private Message to PatrickTRoofEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds good!
str8maxn
Report this Post03-25-2021 05:32 PM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds good!
Agree, not a bad idea.
str8maxn
Report this Post03-30-2021 04:38 PM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
After taking a closer look at the door panels.. There were only a few areas that needed attention. I was able to fix them with super glue and baking soda. I ended up painting them black with duplicolor vinyl and fabric paint. So far I am very impressed with the outcome.
PatrickTRoof
Report this Post03-30-2021 05:25 PM Click Here to See the Profile for PatrickTRoofSend a Private Message to PatrickTRoofEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm curious about this. What exactly did you do?
