| quote | Originally posted by Patrick: That's weird. Normally the pockets are only on the doors of Fieros with electric windows. |
Yes, they go on PW doors.
No handle will fit that right. Most won't fit at all.
Handle and clip for them won't hold or won't turn right if does because of the "pocket" is way too thick.
Often the Handles will also have a large plastic "washer" to go on first to protect the panel.
Side note: The clip for the handle goes open side facing the lever part. This is done so when need to pull it... the tool and handle get pulled at same time.
If done right, the clip will push out but not all the way so won't get lost.
quick example:
https://www.youtube.com/watch?v=JvaQlh8If1sThis time clip stays w/o the tool in. many time the clip will slid back to lock w/o the tool holding it.
This doesn't have the "washer." When there, tool goes between washer and handle.
Many more if isn't enough info.
