  Need some help with door lock switch
Need some help with door lock switch by str8maxn
Started on: 03-21-2021 10:21 PM
Replies: 2 (134 views)
Last post by: str8maxn on 03-30-2021 04:29 PM
str8maxn
Report this Post03-21-2021 10:21 PM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello All,
I'm having issues with the drives side unlock button. During my troubleshooting; I used alligator clips and made contact between the Blue and Orange wires. This locked and unlocked the door.
However , after the 4th try it stop working . I figured a had blown a fuse. I know the fuse for the power door locks is located on slot 15 on a 30 AMP fuse. I confirmed the fuse is good but the door lock switches are no longer working on either side.
The car as an alarm; when I use the remote, both doors lock and unlock.
I am really not sure what's wrong... Any input would be appreciated ..
Thank you
JM
Total ratings: 568
Report this Post03-22-2021 10:17 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
If, IF the alarm is wiring right...
Alarm should be using same OE relays to operate the lock motors/solenoids.
If an OE Switch is bad or have wiring problems, Alarm could "backfeed" the OE switch and blow CTSY fuse.
Orn is "12v" to B pin on OE Switch
Lt Blu is Lock to A pin
Blk is Unlock to C pin
Lock Relay "brick" under the dash has orn/blk power line from PWR ACC fuse.
str8maxn
Report this Post03-30-2021 04:29 PM Click Here to See the Profile for str8maxnSend a Private Message to str8maxnEdit/Delete MessageReply w/QuoteDirect Link to This Post
TheOgre... Thank you for the feed back... I was able to locate the blown fuse. Lock and Unlock was has it should now.
