Zach: The problem that you describe can be any one of a number of things especially a defective sensor, ignition or fueling problem. You can start by going to a chain auto store as many of them will come out and use a code reader on your OBD port to determine if there are any DTC's (trouble codes) . While the codes do not always indicate a specific problem they can guide you to the problem. If you can invest in a PCM scanner, laptop software or find someone locally that can help, that is a better way to focus on the problem. On modern computer controlled engines that is the diagnostic route to take.
