When i plug this new tps sensor, the engine soon service light is on And the idle is surging 1400-1600 rpm cold When i replug my old sensor the ilde is good and stable and the light is off.
It is possible the new tps sensor acdelco is faulty ? I have a 88 fiero v6 and the sensor is comptaible with my 88 v6 fiero. I have proceed to a replacement but before to send this item i want know your advice (bad sensor or bad installation of this sensor is possible ? )
Thank you Greeting.
[This message has been edited by zobari (edited 09-23-2018).]
While it is possible the sensor is bad . . . did you do the relearn? There is a procedure on here that involves putting the car in diagnostic mode momentarily to force the relearn.
I don't know that its always necessary. But, I once had the same idle surging when I installed a TPS, and it was fixed by going through the procedure.
I have searched and I don't see that does need a relearn periode ecm for fieros. I Will receive soon à replacement I let you know if the New one will work propely (i hope lol)
[This message has been edited by zobari (edited 09-27-2018).]
Yes, you should perform an ECM re-learn when replacing the TPS. Otherwise, the TPS voltage will be different from what the ECM is used to, and the ECM will get confused.
I have installed the New tps but same probem I have drive around 20 minutes at 60 mph the service light is turning on and the idle surge beetween 1400 and 1600rpm.
What is the procedure to make an ecm relearn for the tps?
What is it about the new TPS that doesn't allow it to install and/or operate in the proper manner?
Installation ok fit easily. This tps doesn't work properly, the idle is surging and the light service soon is turning on even after drive around 20km but the ecm doesn't relearn.
What leads you to suspect the problem is the TPS?
What trouble codes have been stored?
What are the idle and WOT voltage readings from the TPS?
I came across a video online that might be helpful for someone not familiar with installing and/or testing a TPS.
There have been numerous references in this thread to the ECM needing to "relearn". For a TPS replacement??? I thought that was only necessary when re-installing an IAC valve.
[This message has been edited by Patrick (edited 10-06-2018).]
I have reolug my old tps and ecerything working properly, I would change the tps preventively but my old is working fine.
I suspect This ACDELCO doesn't work with fiero. But on the rear of the tps, I have seen a screw to set up the voltage I presume, my old one doesn't have a screw to setup like the other reference I have wroted below.
