| quote | Originally posted by darbysan: Lou, you do not want to overfill the boots with grease. When the boot compresses with axle movement, it can cause the boot to split due to hydraulic pressure of the grease. I bag per side ( several oz) is usually all you need. I think I paid about $4 in the Help section. When you buy a boot kit, it is supplied with just that amount of grease, along with the boot and clamp. |
Yup... Too much grease will made boots or bands to fail soon.
Dorman 3 oz. Packet 03618 is $2 - $4
One pack, maybe two, per CV in most cases.
Grease in the boots is mainly to keep grease in the joint. Is a lot of force trying to "spin dry" lube off the joint. Extra in the boot keep grease level high enough to do the job.
You can get 10 pack of packets thru Ebay etc for < $40.
CV grease isn't same formulas as Many others. Big problem is others have additives will attack the CV boots, brake rubber parts, and so on. (Helps to keep seals soft but ruins boots etc.)
