  87 gt Fiero start up (Page 2)
87 gt Fiero start up by 0WNINGD3ATH
Started on: 04-09-2016 10:59 PM
Replies: 49 (1086 views)
Last post by: 0WNINGD3ATH on 04-30-2016 10:02 PM
Total ratings: 291
Report this Post04-24-2016 09:40 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
0WNINGD3ATH
Report this Post04-24-2016 10:42 PM Click Here to See the Profile for 0WNINGD3ATHSend a Private Message to 0WNINGD3ATHEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh wow.. I feel stupid haha. I just went out and looked and I see that the injectors are not plugged into the aluminum piece. They hook into the piece that sits below that. 😂😂😂
Total ratings: 466
Report this Post04-24-2016 11:48 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
They're plugged into the lower "aluminum piece".
0WNINGD3ATH
Report this Post04-28-2016 12:35 AM Click Here to See the Profile for 0WNINGD3ATHSend a Private Message to 0WNINGD3ATHEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know why but my images won't upload through the PIP program. I've made some progress. I got the car pretty much back together. I installed new plugs, wires, distributor cap, rotor, coolant temp sensor, thermostat, new gaskets for alot of crap, and cleaned up and repainted my valve covers and upper intake manifold. Overall, the car is looking good again and will be running (hopefully) tomorrow. Just waiting to spray another few coats on the top side of my manifold tomorrow. Thought I'd throw up some progress photos. As before, just right click and open in another browser.
0WNINGD3ATH
Report this Post04-28-2016 10:55 PM Click Here to See the Profile for 0WNINGD3ATHSend a Private Message to 0WNINGD3ATHEdit/Delete MessageReply w/QuoteDirect Link to This Post
0WNINGD3ATH
Member since Jan 2016
Well, all is good except for one thing. That's the fuel line that supplies the fuel for the fuel rail. It doesn't leak when I put pressure down on it, but does as soon as I let up. The nut around it is pretty much as tight as I can get it. I already tried to straighten the line out and that helped but just seems like I should somehow be applying more pressure to the line. any thoughts? This one's truly got me stumped.
The line looks like this:
[This message has been edited by 0WNINGD3ATH (edited 04-28-2016).]
Total ratings: 466
Report this Post04-28-2016 11:36 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...the fuel line that supplies the fuel for the fuel rail. It doesn't leak when I put pressure down on it, but does as soon as I let up.
That looks like the fuel line to the cold start injector. What was the condition of the O-ring?
[This message has been edited by Patrick (edited 04-28-2016).]
0WNINGD3ATH
Report this Post04-29-2016 12:38 AM Click Here to See the Profile for 0WNINGD3ATHSend a Private Message to 0WNINGD3ATHEdit/Delete MessageReply w/QuoteDirect Link to This Post
It looked fine, although it didn't come out when I pulled out the line. But it could be just a tight fit. And after looking at a few diagrams, it is intact the line for the cold start. I'm to the point where I'm about to put gasket sealer around the line and call it good because I really don't want to pay 9 bucks for a kit that I only need that tiny gasket out of. This line is the only thing stopping me from having everything together.
[This message has been edited by 0WNINGD3ATH (edited 04-29-2016).]
Total ratings: 466
Report this Post04-29-2016 01:00 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do NOT mess around with short-cuts here... unless you want the whole car to go up in flames. I'm am not kidding around. You do not want a gas leak.
0WNINGD3ATH
Report this Post04-29-2016 09:29 AM Click Here to See the Profile for 0WNINGD3ATHSend a Private Message to 0WNINGD3ATHEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah I know. Just frustrated lol.
0WNINGD3ATH
Report this Post04-30-2016 10:02 PM Click Here to See the Profile for 0WNINGD3ATHSend a Private Message to 0WNINGD3ATHEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I was looking around and found a kit with a bunch of o rings. I grabbed some that were similar in size and put them in. I put 2 under the wide part of the fuel line and put 3 on top of it to stop it from moving when I tightened the nut down. It doesn't move at all and doesn't leak. I left the key on for a good 10 minutes and just watched. No leaks or anything when pressurized. I put everything together and there was a few leaks. Thank god the gasket set from the fierostore came with rtv. I'm almost positive I got the leaks but haven't smoke checked it. I haven't driven it yet but will later today or tomorrow. But for now, I'm calling it a success.
[This message has been edited by 0WNINGD3ATH (edited 04-30-2016).]
