  silver sheen to my oil
silver sheen to my oil by Ramon
Started on: 11-29-2015 11:35 PM
Replies: 24 (1881 views)
Last post by: Gall757 on 12-15-2015 05:07 PM
Ramon
Report this Post11-29-2015 11:35 PM Click Here to See the Profile for RamonSend a Private Message to RamonEdit/Delete MessageReply w/QuoteDirect Link to This Post
History, fresh 1995 Camaro 3.4 swap 28,000 miles on engine. about 130 miles after the swap and maybe 2 hours of idle time. I replaced rear main seal, timing chain, timing chain damper, timing chain seal, head gaskets, head gasket bolts, valve seals, water pump.
Ive been having low oil pressure when oil is hot so low the light comes on. when cold it around 60. I know this is a common problem. The engine runs smooth no grinding sounds or pinging. I can see smooth oil flow under the oil fill cap. I did not replace the oil pump which was dumb. I drained the oil and it has a silver sheen. no flakes at all just a silver sheen. when you run your finger through the oil it makes a silver/grey trail. I'm wondering if I have done damage to my bearings? or maybe timing chain breaking in causing the silver? I am ordering a new pump tonight. maybe a high volume. I'm a little against that I hear a high volume can wear the dis gear faster. Your guys thoughts.
Total ratings: 461
Report this Post11-30-2015 05:51 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you use assembly lube on anything? I think it can make the oil look funny. It can also plug the oil filter in pretty short order, and make it "bypass", I think.
Other than that, the silver doesn't sound like a good thing.
Good luck.
Ramon
Report this Post11-30-2015 10:34 AM Click Here to See the Profile for RamonSend a Private Message to RamonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes I did use lube on the pushrods and a little on the cam lobes. I'm going to change the pump today or tomorrow, also flush and change the oil and filter. I'm hoping that with only 130 miles on the swap if I did do damage its not to severe . I'm thinking of also checking the bearing gap clearances... What other areas should I check while I have the pan and pump off? Maybe there is something clogged somewhere.
Blacktree
Total ratings: 350
Report this Post11-30-2015 04:30 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
A visual inspection of the main and rod bearings would be a good idea. It would also be a good idea to check the camshaft and lifters. But that would require removal of the intake manifold.
dobey
Total ratings: 371
Report this Post11-30-2015 04:48 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
You didn't specify what oil you used. What oil is it? How much zinc is in it? Detergents? Got a picture showing the silver sheen of the oil?
rogergarrison
Total ratings: 551
Report this Post12-01-2015 05:10 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Usually silver in the oil indicates metal.
Monkeyman
Total ratings: 182
Report this Post12-01-2015 07:10 AM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't worry about it. You just used an inferior oil. The "good" oil would have left a gold sheen. At least you didn't use the "bronze sheen" oil.
dobey
Total ratings: 371
Report this Post12-01-2015 10:18 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The best oil for winning gives you a Charlie Sheen.
Done with the wisecracks? The question about what oil is used is important. The wrong oil can provide poor protection and result in more metal contact, and thus metallic content in the oil. Certain additives could also cause the oil to appear different color. When asking questions about why your oil looks a certain way, it's generally courteous and a good idea, to actually specify what oil you're using, and what additives if any, including amount added. It helps to find the problem, and in the case the oil or additives are at fault, inform others about the problems with that oil or additives.
hobbywrench
Report this Post12-01-2015 01:28 PM Click Here to See the Profile for hobbywrenchSend a Private Message to hobbywrenchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why not have an oil analysis done. Easy online sources and not too costly..?$45?"
Ramon
Report this Post12-01-2015 02:43 PM Click Here to See the Profile for RamonSend a Private Message to RamonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry fellas they have been working us to death during the holidays... The oil I used was Supertech 5w30. with stp added.
dobey
Total ratings: 371
Report this Post12-02-2015 11:28 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Definitely get the oil analyzed.
I'd be a bit more worried about cam lobes than bearings though. But I'd not start the car before getting the oil analysis, and checking at least the rod bearings, at this point. If you have any of the oil and STP left, I'd also mix both a bit in a clean container, and also send that off for analysis, to compare against what came out of the car, as well.
RotrexFiero
Report this Post12-02-2015 11:47 AM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stick a magnet in it.
Report this Post12-02-2015 05:11 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I suppose Id change the oil and filter, run it and and check it again. Id use a break in oil, high in zddp.
[This message has been edited by 2.5 (edited 12-03-2015).]
Total ratings: 466
Report this Post12-02-2015 07:42 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by Patrick (edited 12-02-2015).]
Deabionni
Total ratings: 116
Report this Post12-04-2015 09:54 PM Click Here to See the Profile for DeabionniSend a Private Message to DeabionniEdit/Delete MessageReply w/QuoteDirect Link to This Post
Blackstone Labs only charges $28 for an analysis, and will send you the kits for free. You only pay when you send in the oil for analysis.
viperine
Report this Post12-04-2015 10:53 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
I built a 406 sbc for my trans am, everything was brand new to a freshly machined block. I broke the engine in with Brad penn break-in oil (thick as -expletive-!) And my first oil change scared me, that silvery film. Turned out to be the assembly lube. Next few oil changes improved. May consider 20-50w oil, I use it for most of my cars. Slightly better gauge reading so it isn't irking me every time I drive. Perhaps an oil cooler (the kind that L98 vettes got) would improve viscosity at operating temps. Lastly, you could always get an accurate reading with a trusted gauge at the block. My mechanic wants to smack me any time I worry over what readings I see in our horribly innacurate factory gauges.
Ramon
Report this Post12-04-2015 11:08 PM Click Here to See the Profile for RamonSend a Private Message to RamonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think I will do the analysis Whatever has been done has been done. The engine still sounds and runs awesome with great compression. I have the Melling M134HV oil pump I am waiting for the pickup tube should be here this Wednesday. I am also using Valvoline Max Life Full Synthetic this time with Lucas oil TB Zinc-Plus. The pickup tube is going to be a problem because all I have to weld it to the pump is a arc welder with 7018 rod. I've been told I could use red thread lock. ??? I don't know about that but the 2.8 had nothing keeping it pressed in, the pump seemed to be rock solid after 103k. I'll keep you all updated. thanks guys for your input.
viperine
Report this Post12-04-2015 11:22 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK forgive my lack of knowledge pertaining to the 2.8 as most of my roots are in SBC's, but for bypassing the tack weld for oil pump pickups, pioneer products makes a clamp to hold it in place for small blocks. I would hope this clamp could work for a v6, or that the v6 has its' own version, but I have yet to look at a v6 oil pickup. Might be worth looking into.
Ramon
Report this Post12-04-2015 11:33 PM Click Here to See the Profile for RamonSend a Private Message to RamonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jegs also makes one... I wonder if this retainer can b used on the 3.4 and 2.8 pumps?
Retainer
http://www.jegs.com/p/JEGS-...iner/751362/10002/-1
Ramon
Report this Post12-15-2015 01:40 AM Click Here to See the Profile for RamonSend a Private Message to RamonEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK guys here is a video of what I have been talking about. What I have done since my last post is I have changed out the oil pump to a Mellings HV oil pump. After oil warms up I'm getting 20 to 25 on the car oil gage. which I think is low do to the fact I have a hv pump.
After playing back the video I have noticed a metal on metal sound coming from the front of the engine. kinda like brake pad to rotor metal on metal. Not sure if I'm hearing things. Maybe something in the timing chain area Hmmm? but still low oil pressure after a new hv pump seems odd.
https://youtu.be/Uo3fAg7Ez6k
Total ratings: 466
Report this Post12-15-2015 02:30 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice clean looking engine!
When you say "metallic", are you referring to sparkly things in the oil. If so, I can't see them, although better lighting might've helped.
Or are you referring to the gray looking mud that you were stirring up in the drain pan?
dobey
Total ratings: 371
Report this Post12-15-2015 09:16 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
20 to 25 at idle on a warmed up engine is normal. HV is just volume, not pressure. It pumps more volume at roughly the same pressures as stock.
I don't hear the metal sound from the front of the engine that you're mentioning, but it could be the water pump, or just alternator whine.
As for the metallic look in the oil, to me it looks like it's a bit cloudy when you stir it with your finger, so more than likely this is just the assembly lube/zddp additive being stirred up and making the oil look cloudy.
Blacktree
Total ratings: 350
Report this Post12-15-2015 11:47 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your oil pressure is fine. And the engine seems to be running well.
Keep in mind that break-in lube has a mild abrasive in it. It helps to polish the cam lobes, lifter faces, etc to a mirror-like finish. Of course, that polishing action does remove some small amounts of material. So your break-in oil will have a metallic sheen. That's perfectly normal.
After you change out the break-in oil for normal engine oil, there shouldn't be any more metallic sheen in the oil.
Ramon
Report this Post12-15-2015 03:23 PM Click Here to See the Profile for RamonSend a Private Message to RamonEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Grey looking mud is what I'm referring to.
Thanks fellas for your input
Report this Post12-15-2015 05:07 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Why don't you run a test in a clean pan. Add the Lucas stuff to some oil and see if you can make the gray mud.
Your valvetrain sounds noisy to me. I don't know how that may be a factor though.
