  Is there an aluminum block/heads
Is there an aluminum block/heads by mcguiver3
Started on: 10-17-2014 08:13 AM
Replies: 24 (1202 views)
Last post by: Blacktree on 10-19-2014 05:22 PM
mcguiver3
Report this Post10-17-2014 08:13 AM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
As listed.
Is there an aluminum block for either the 2.8 or 3.1?
Just thinking out loud.................
jaskispyder
Total ratings: 205
Report this Post10-17-2014 08:18 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I remember something about an alum. 2.8L that someone had, but I can't remember if it was an exact fit or what. Anyway, you may want to try the Forum Search, or just google for "Aluminum 2.8l Fiero"
Total ratings: 236
Report this Post10-17-2014 08:35 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
There was aluminum Bow Tie (made for motorsports) block with cast iron liners in the GMPP catalog back in the day. They pop up on ebay and racing classifieds every now and then. These can handle 700+ HP when turbo'd.
There were a very few prototype production aluminum blocks made. They were linerless and made of hypereutectic aluminum. They had a bolt in lifter bore carrier like the 4.9. A few of them surfaced when GM was going through its bankruptcy proceedings, but I've only heard of 2 or 3 making it out into the world. Don't expect these to be any stronger than the regular production iron blocks.
Report this Post10-17-2014 08:43 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
You may be thinking of this....3.8
http://www.taperformance.co...il.asp?prod=TA_V3800
hookdonspeed
Total ratings: 131
Report this Post10-17-2014 02:15 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
keep an eye on 60degreev6, was a new bowtie block just sold recently.
ericjon262
Report this Post10-17-2014 04:16 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
gen 2 and gen 3 heads are aluminum, and flow much better than the stock iron heads...
Total ratings: 236
Report this Post10-17-2014 04:59 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are still a few around... I'd like one, but I'd also like to run the 99mm bore of the late 3500 (can never remember LZ9 vs. LX9) and 3900
ericjon262
Report this Post10-17-2014 06:28 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
LZ9
Report this Post10-17-2014 07:13 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was asking about that HERE.
It's not a straight "bolt on" though... right?
lou_dias
Report this Post10-18-2014 04:38 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it is targeting Buick owners, it's probably a RWD bolt pattern...
dobey
Total ratings: 371
Report this Post10-18-2014 05:44 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's a clone of the pre-3800 3.8 block, so I think it's the BOP pattern, though it might be the big Chevy V8 pattern, given their target is race applications.
(The metric pattern of the 60 degree V6 is used in both FWD and RWD applications.)
ericjon262
Report this Post10-18-2014 07:03 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
depends on your definition of "straight bolt on". you have to use the gen 2 or 3 intakes as well, Gen 2 may be able to use stock exhaust manifold, not sure, gen 3 would require re-working the exhaust. after that the only big thing I can think of is a tune.
Edit: I forgot about compression ratio, this combo makes the compression ratio very high(not bad for a race application)
[This message has been edited by ericjon262 (edited 10-19-2014).]
sleevePAPA
Report this Post10-18-2014 08:03 PM Click Here to See the Profile for sleevePAPASend a Private Message to sleevePAPAEdit/Delete MessageReply w/QuoteDirect Link to This Post
The TA block uses dual patterns for BOP or Chevy corporate large bellhousing.
lou_dias
Report this Post10-18-2014 09:38 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I know the Firebird had a RWD 5 speed in that pattern for the 2.8 but I don't recall anything else.
dobey
Total ratings: 371
Report this Post10-18-2014 10:19 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
RWD 3800s use metric pattern, as do RWD versions of the 2.2, 2.5, 2.8, 3.1, and 3.4; all of which came in the F-body cars or S trucks.
ericjon262
Report this Post10-19-2014 01:54 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
S trucks got the 2.8 or 4.3 no 3800's there.
Report this Post10-19-2014 03:04 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Edit: I forgot about compression ratio, this combo either makes the compression ratio very high (not bad for a race application) or very low. I forget which, but I'm pretty sure it goes way up.
Changing pistons for a head swap... minor detail, eh?
dobey
Total ratings: 371
Report this Post10-19-2014 09:24 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, they got the 2.2, 2.5, and 2.8, for engines with the metric bell pattern. The F-body did get the 3800 though. Point was that F-body and S-trucks both were RWD and had metric bell pattern engines, not that both came with all the listed engines at some point.
ericjon262
Report this Post10-19-2014 11:28 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
it takes the compression ratio up, for a race application, that's not exactly a bad thing.
TopNotch
Total ratings: 60
Report this Post10-19-2014 11:49 AM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
GM 2.8 Aluminum Bow Tie Block
No longer available, but you may find one on Ebay.
dobey
Total ratings: 371
Report this Post10-19-2014 01:17 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd be less worried about the compression ratio, and more worried that the pistons and valves will collide, given the change in valve angle and the use of dished pistons in the gen II engines. If you don't change the pistons and slap on the gen II heads, you'll probably find yourself needing a bunch of new things very quickly.
ericjon262
Report this Post10-19-2014 01:35 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
it's been done before without problems, doesn't mean it can't happen though.
Report this Post10-19-2014 03:03 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If we go back in history GM developed an all aluminum block V6 engine that was used in the Oldsmobile Cutlass & Jetfire. This had to be back in the 1960's. The engine was not a success and was sold to British Leyland or it might have been Land Rover. Eventually the engine came back to the states became the 3.1L and was made in cast iron. So to answer the question 60* v6 engines were made in aluminum but why would you want one when better engines are available?.
ericjon262
Report this Post10-19-2014 05:03 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
completely different engine designs, you're a moron.
Blacktree
Total ratings: 350
Report this Post10-19-2014 05:22 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Dennis LaGrua: If we go back in history GM developed an all aluminum block V6 engine that was used in the Oldsmobile Cutlass & Jetfire. This had to be back in the 1960's. The engine was not a success and was sold to British Leyland or it might have been Land Rover. Eventually the engine came back to the states became the 3.1L and was made in cast iron.
I think you're confusing a few engines with each other. First of all, the 215 V8 (aluminum block and heads) was sold to the Rover Group. The Fireball V6 was not. Also, the Fireball V6 was based on the 215 V8, but had an iron engine block. And it's the ancestor to the Buick 90-degree V6 engines (3.8, 3300, 3800), not the 60-degree V6. The 60-degree V6 (2.8, 3.1, 3.4, 3100, 3400, 3500, etc) is a completely different engine family... a clean-sheet design from Chevy.
Also, the aluminum "bowtie" blocks for the 2.8 V6 were made specifically for motorsports. AFAIK, it was never offered in a production vehicle.
[This message has been edited by Blacktree (edited 10-19-2014).]
