This past weekend I pulled my wiring harness out of my 3400 swap fiero (running OBD2) to solder connections and remove excess wire. Car started and runs fine but I noticed my reverse lights no longer work. I believe I have tracked it down to the c500 pin C1 being disconnected and possibly E1 sent to ground (I can not remember if It was always wired like this or if I made a mistake/pulled wires loose when removing the harness from the car.)
Car is an 86 GT with 4 speed manual (so reverse light switch is on the shifter mechanism)
Here are the diagrams I have been going off of trying to figure this out. Where do I connect the C500-C1 (blue) and E1 (lt green)?
Another issue I have gained after reinstalling the wiring harness is that my turn signals no longer work, at all. The hazards will flash though. Could this be caused by removing the C500? H7, H8, H9, and J8 say "Lights: Turn/Stop"
