| quote | Originally posted by Gambit:
Hi guys, after a lot of hassle i bought a camaro 1994 3.4 pushrod engine complete which i intend to run with a 7730 ecm with DIS.
Now the question and i did read the entire forum. Are there any good upgrades on this engine. I have a truleo intake and truleo exhaust, 19 lb injectors and the FS stainless steel valves. I will pick up the engine next week and than i will begin. Should i also use the fiero heads or the camaro heads? Any info is really appreciated guys. |
You already have good upgrades for the intake and exhaust. There is no difference between Fiero 2.8 heads and the Camaro 3.4 heads. The Fiero rear head already has the coolant temp sender (temp gauge) in the correct place whereas the Camaro rear head will have to have a plug removed and the sender installed. I would used which ever are in better shape.
To be fair, you probably did not read the
entire forum...
There are a lot of threads here on modifying iron head engines... there is a search button underneath the 'New Topic' and 'Post Reply' buttons up at the top of the page. Make sure that when you search, you select 'Entire Forum + Archives' as well as noting whether you are searching Subject/Username or Entire Threads. I find that while searching entire threads will return more results, using the Subject/Username will return more usable results.
You can also use Google to search by putting 'site:fiero.nl' in your
search terms. Google is much better at context searching than the built in forum search.
By just putting 3.4 PR in the forum's search function, it returns
70 links to threads about pistons, cams, ecms, clutches, etc...
You can also look on the
ThirdGen.org V6 F-body forums, there are good resources there as well.
[This message has been edited by carbon (edited 03-03-2014).]
