  Battery Drain
Battery Drain by WhateverUSMC
Started on: 02-21-2014 03:51 PM
Replies: 6 (178 views)
Last post by: WhateverUSMC on 02-22-2014 12:19 PM
WhateverUSMC
Report this Post02-21-2014 03:51 PM Click Here to See the Profile for WhateverUSMCSend a Private Message to WhateverUSMCEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know there is some info out there on this, but I need help with the multimeter. I want to test the battery. It is a new battery, but at this point, I don't think I have anywhere else to check. I've disconnected the lid light, checked the fuses (no sparks), headlight motors are fine, everything is off.
I was hoping that someone could tell me what to set my multimeter to. Different websites say 'ohms', or volts, but I can't seem to find any concensus. Would really appreciate the help, as this is driving me batty.
TY
Report this Post02-21-2014 04:37 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Testing the battery, and testing for battery drain are 2 very different things. Which one do you want to do?
To test the battery, take it to an auto parts store where they can put a load on it ....you can't do that with a multi meter.
To look for battery drains, set the multimeter to Amps. start high (for safety) and go lower to the milliamp range. A normal drain is 50 milliamps, or 5% of one Amp.
[This message has been edited by Gall757 (edited 02-21-2014).]
rogergarrison
Total ratings: 551
Report this Post02-21-2014 05:00 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lets see if I remember this right. Disconnect the ground battery cable at the battery and connect a test light between the cable end and the battery post. It will lite up if theres a drain. Pull fuses one at a time till it goes out and you found whats draining it.. If I got it wrong, someone will correct me Im sure...
Report this Post02-21-2014 05:29 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
See my Cave, Battery Leaches
James Bond 007
Total ratings: 263
Report this Post02-21-2014 05:40 PM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
I once had a massive power drain,turned out to be the headlight motors. The headlights functiond normalley,no unusual noises. I disconnected the single power wire to the right and left healight motors (dont pull the fuse or you'll lose your brake lights) and the problem went away. A stuck fan relay could cause this problem too,but you'de notice that.A bad diode in the alternator could allso cause this problem.Be sure to check Ogres Cave.
NetCam
Report this Post02-21-2014 08:55 PM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can-Tech makes a good cheap solution for finding which circuit has the drain, easy to use too, Harbour Freight sells it for around $13.
WhateverUSMC
Report this Post02-22-2014 12:19 PM Click Here to See the Profile for WhateverUSMCSend a Private Message to WhateverUSMCEdit/Delete MessageReply w/QuoteDirect Link to This Post
Turns out, the drain was from a bad aftermarket radio install. Goes to show ya; check the blatantly obvious first! Thanks, all!
