  Trying my hand at the sunbird turbo tach swap.
Trying my hand at the sunbird turbo tach swap. by Tweeder
Started on: 02-02-2014 07:24 PM
Replies: 21 (722 views)
Last post by: hercimer01 on 02-23-2014 04:19 AM
Tweeder
Report this Post02-02-2014 07:24 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have it all in and wired... I think but i.m getting no reading on the tach. I have a 5K linear potentometer, is that the correct one? Is there any way to bench test the tach to see if I have it hooked up right.
[This message has been edited by Tweeder (edited 02-02-2014).]
hercimer01
Report this Post02-03-2014 04:41 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
1Meg Ohm Potentiometer installed across where R14 should go. Check out the last page of my Sig.
88 Coupe under construction
Tweeder
Report this Post02-03-2014 04:59 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will have to double check when I get home from work on the wiring. But do I have the correct potentiometer? I told them a 1meg ohm.
Tweeder
Report this Post02-03-2014 07:17 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tweeder
Member since Aug 2012
This is how I have mine now. My board is a little different than yours. You can see where I had the one wire before. The one I left alone(the one that has the two pins side by side). As it looks like they are joined. Is that correct? The way I gave it now still doesn't work. Not sure if it's my wiring or the potentiometer.
hercimer01
Report this Post02-04-2014 12:13 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am sure your Potentiometer value is wrong. I have only seen people using 1 Meg Ohm Pots.
Your wiring looks correct.
Are you using this thread?
https://www.fiero.nl/forum/A...130314-2-110302.html
Tweeder
Report this Post02-04-2014 08:16 AM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's how I originally had it wired but I changed it to match yours. But like I said, our boards are a little different. I will order another potentiometer, the person who ordered it for me screwed up. Does it matter what kind or potentiometer? I see a clarostat, audio, linear, or just as long as it's a 1m ohm?
[This message has been edited by Tweeder (edited 02-04-2014).]
hercimer01
Report this Post02-04-2014 08:12 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just went to my local electronics wharehouse and said I need a 1 Meg Ohm Pot.
I think linear is for audio. But it shouldn't matter, Linear just means what the ramp of the increase in resistance does when you turn it up.
Is there a Frys electronics around you? They would have something.
Edit; Im pretty sure the only difference in mine and yours as far as our mod wiring goes is that the older tach like yours has a different map sensor input (Green wire) The Pot goes in the same place.
[This message has been edited by hercimer01 (edited 02-04-2014).]
Tweeder
Report this Post02-04-2014 08:20 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
We have no electronic stores near me, I'm at the end of a road way up north. I'll have to order it online. I'm thinking this?
http://www.ebay.com/itm/Phi...ometer-/200845882155
hercimer01
Report this Post02-04-2014 08:33 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thats way to big. You could dim all your dash lights with that.
I used one like this. http://www.ebay.com/itm/1-M...&hash=item1c14f1b19a
Tweeder
Report this Post02-04-2014 08:36 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, I'll look for that one. Unfortunately, yet another person that doesn't ship to canada.
hercimer01
Report this Post02-04-2014 08:41 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.ebay.ca/itm/10pc...&hash=item20d6522047
I used it like this.
Tweeder
Report this Post02-04-2014 08:58 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for that I was looking at the same time you posted lol. I have been able to locate one in Canada to speed up shipping.
Tweeder
Report this Post02-07-2014 10:47 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you look at the board in the link https://www.fiero.nl/forum/A...30314-2-110302.html, it's wired different than yours.
Tweeder
Report this Post02-10-2014 06:07 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bum for te question above as I just got the pots in the mail. Also does it matter which wire goes where? I want to make it work this time.
hercimer01
Report this Post02-10-2014 08:09 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Earlier one like you have and the later one like I have at pretty much the same for what were doing.
The first two pics show the earlier Tach Mod.
The later one there are provisions for a spot R14 resistor that was never installed. This is where the trimmer pot goes on mine.
E1 and pin5 of the top chip are where the trimmer pot goes. Remember you are only using the middle leg of the trimmer pot (or wiper) and either one of the other legs.
The micro chip on the late one has been clocked differently but the foil runs still go to the same legs on the chip.
And the cut would be the same.
SCCA FIERO
hercimer01
[This message has been edited by hercimer01 (edited 02-10-2014).]
Tweeder
Report this Post02-16-2014 03:30 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got the new potentiometer in and hooked up but i get no response from the tach still. Is there any way to test the tach? I'm not even sure it works?
hercimer01
Report this Post02-17-2014 01:02 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Can you post some pics of how you wired it?
Tweeder
Report this Post02-18-2014 05:48 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heres how I have it wired in the back
Hers the wires on the circuit board
Hers how the potentiometer is soldered to the board. I tried moving the wire out of the way to get a better pic but it broke off. It looks like it broke off below the board so I filed it down in hopes that when I re solder it will make contact.
hercimer01
Report this Post02-19-2014 02:44 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
From https://www.fiero.nl/forum/A...130314-2-110302.html
The yellow circle shows where it looks like it may have been shorted to ground on that foil run.
The purple circles show where the trimmer pot should be soldered. ( same as the leg on the chip, just easier to deal with.)
I can't tell if you cut the foil run
Tweeder
Report this Post02-19-2014 01:55 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Now I'm confused, I have the older style from what I understand. Shouldn't I have it wired like you have it in the first pic? That's the way I had it initially. Or just do it the way you have it in the second pic?
Tweeder
Report this Post02-22-2014 12:27 AM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump.
hercimer01
Report this Post02-23-2014 04:19 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry. Working 12 hour days. Work and sleep lately.
Either way is the same, or "correct"
I still think your solder job shorted out initially. I just showed the alternative so when you resolder it, you could have easier access.
