  loss of fuel pressure 2.8
loss of fuel pressure 2.8 by pgold
Started on: 01-25-2014 09:31 AM
Replies: 13 (296 views)
Last post by: ericjon262 on 01-26-2014 08:51 PM
pgold
Report this Post01-25-2014 09:31 AM Click Here to See the Profile for pgoldSend a Private Message to pgoldEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am having a loss of fuel pressure when i shut off my 2.8 motor. I have replaced the fuel pump and seal on the fuel block with no success. then i replaced all the injectors and fuel pressure regulator with no success. The only thing that i haven't replaced is the cold start injector since i can't seem to find one anywhere. What can i do to resolve this problem?
paul gold
Csjag
Report this Post01-25-2014 09:40 AM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you checked your vapor canister and the lines to it?
Report this Post01-25-2014 10:43 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the Forum!
You should have no trouble finding parts (or advice) in Las Vegas.
http://www.lasvegasfieroclub.com/
pgold
Report this Post01-25-2014 05:38 PM Click Here to See the Profile for pgoldSend a Private Message to pgoldEdit/Delete MessageReply w/QuoteDirect Link to This Post
My vapor canister appears to be fine and all the hoses are new and secure. Can the cold start injector be bleeding off?
NetCam
Report this Post01-25-2014 10:01 PM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you try Rock Auto for the cold start injector?
ericjon262
Total ratings: 67
Report this Post01-25-2014 10:16 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
is the fuel pump running? is the fuel pump relay working?
Blacktree
Total ratings: 350
Report this Post01-26-2014 10:08 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
You're saying the fuel pressure drops after turning off the engine. So I'm assuming fuel pressure is OK while the engine is running? And just out of curiosity, how fast does the fuel pressure drop? Does it drop to zero immediately, or does it take a few minutes? Also, does the engine run rich,? And does it spit out raw gas fumes while starting?
pgold
Report this Post01-26-2014 04:25 PM Click Here to See the Profile for pgoldSend a Private Message to pgoldEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have not tried rock auto for the cold start injector. The fuel pump is working fine . Fuel pressure when running seems to be good . only when the motor is turned off does it slowly loose pressure. It does seem like there is some slight fuel or condensation that has come out of tail pipe, but it is so slight that you barely see it. I did install a fuel pressure gage that i got form the fiero store which is installed into the shredder valve. when i shut off the motor you can watch the pressure slowly drop . its not a fast drop but within 20 seconds there is 0 fuel pressure in the fuel rail. This is making me crazy!
Blacktree
Total ratings: 350
Report this Post01-26-2014 04:41 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds to me like your fuel delivery system is working fine. That said, it wouldn't hurt to check the cold-start injector, just in case. But it's perfectly normal for the fuel pressure to slowly drop after the engine is turned off.
ericjon262
Total ratings: 67
Report this Post01-26-2014 05:46 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
almost all efi systems will slowly lose pressure in the rail over time, how long does it take for the pressure to bleed down? instant? a couple minutes, and hour?
Report this Post01-26-2014 06:15 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
ericjon262
Total ratings: 67
Report this Post01-26-2014 06:19 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Gall757:
whoops, thanks.
to the OP, you can try capping off the cold start injector at the fuel rail, IIRC, the threads are M12x1.75. if fuel pressure stops falling off, the CSI is probably your problem.
another thing you can do, easier then plugging the CSI, get a stethoscope with a probe, most auto parts stores carry them, and touch the probe to the CSI and listen for flow.
[This message has been edited by ericjon262 (edited 01-26-2014).]
pgold
Report this Post01-26-2014 07:38 PM Click Here to See the Profile for pgoldSend a Private Message to pgoldEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the cold start injector is determined to be the problem can it be disconnected and capped off on the fuel rail and block and no even used?.
ericjon262
Total ratings: 67
Report this Post01-26-2014 08:51 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would cap it off on the rail, remove it, plug the hole in the intake, and swap to a 7730. yeah, you could just plug it, but IIRC, the stock tune in the ECM is calibrated for it to be there.
1st class A**hole.
