I am just about done building my 3800 sc series 2 to put into my 88 formula and I have a few questions on tuning:
I have the harness apart and will begin building it up. What is the best year pcm to use? The engine is from a 97 Park Ave ultra. I have heard some PCM's won't physically fit in the fiero console space.
I will be keeping the egr and boost bypass and have added a VS cam and powerlog manifiold. I would like to do the tune myself. I have many years electronic experience and all the necessary programmers, eproms, erasers etc.
Are there any bin files out there for tuner cat with this config for a starting point? And which year PCM would be best?
I know I could go to ZZP and get a PCM already programmed as well as the many other sources but I would like to do it myself.
EDIT: OK I did a little more searching and looks like I want to go with a 98 and up PCM. I will wire it to a 97 harness following gmtuners schematics. Still looking for the dumps to get started.
[This message has been edited by TbirdMarc (edited 01-22-2014).]
Thanks for the reply. So this would have the correct programming for the VS cam? Does it have to be a GTP PCM or just a regular GP? Any ideas on where to get a dump? Thanks!
Has to be a gtp pcm for various reasons including the 2bar map.
I would recommend tuning for the vs cam to get the most out of your engine. Even stock cars get benefit from a good tune, never mind a modified swap. Also get familiar with KR
One more thing. Is your tuner cat a version that is set up for obd II tuning? I'm used to hearing it used for obd I .
You are probably right about that. i looked into HPTuners VCM, but it seems like a PITA with the credits and all. Is there a free OBD2 scan/programmer that anyone uses. I did a lot of research on KR,. ZZP had a good writeup about it in their tech section. I will probably go with a preprogrammed unit from ZZP, but I would like to get some hands on to better understand things.
Nothing that I know of. I used DHP Powertunr to get my feet wet. Its unlocked for pretty much all series 2 ecm year. You can get that for 200-250 shipped. However the company has gone under so there is zero support.
I have now added an hp tuners vcm pro to my tuning hardware/software. You can get a used one for 350-500 with some credits left if you act quickly when ones comes up. Its much more expensive but its still current and theres lots of support, havent had a chance to play much to get experience but the graphic tables seem really handy too.
Looks like HP Tuner along with Tiny Tuner will get me started, also found a load of bins here:
DHP software is available online, all you need is an AVT-841 cable(others may work, not sure). that with tiny tuner can do most of what you should need in the way of tuning for way less than HPT.
[This message has been edited by ericjon262 (edited 01-25-2014).]
Found the DHP software, been looking around for the cable today. Would be nice to find specs to build one.
[This message has been edited by TbirdMarc (edited 01-26-2014).]
Are any of these interfaces native usb or do I need a USB to serial adapter. I know sometimes that's flakey. I guess it doesn't matter which one I get, the 838 or 841?
neither are native USB that I am aware of. I'm pretty sure the 841 is just an updated 838 can't say 100% though.
What cables do I need. It looks like a DB9 out one side. Is the other odb2 to odb2? f you can let me know the connectors and gender that would be real helpful.
I remember looking at those interfaces when my dhp went wonky. If I remember correctly one or them was a usb based interface that could work. Email the supplier, I think he knew and several ppl had bought them to use with dhp software.
aparently a 842 is usb and works with the DHP software.
