  rim/tire size
rim/tire size by newfiejeff
Started on: 12-31-2013 11:23 AM
Replies: 11 (548 views)
Last post by: jb1 on 01-03-2014 09:28 PM
newfiejeff
Report this Post12-31-2013 11:23 AM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey all, I have checked out the wheel/tire size chart and I am looking at 4 18 inch rims with 225/40 tires on it. It says the speedo will be off by a nice bit but would I have any other issue?
gtoformula
Report this Post12-31-2013 11:34 AM Click Here to See the Profile for gtoformulaSend a Private Message to gtoformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fit/clearance will depend on wheel offset.
newfiejeff
Report this Post12-31-2013 11:34 AM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
Owner of tire and rims thinks it is a 38 offset.
Report this Post12-31-2013 11:48 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
You need the famous 'Joe Torma' Chart!
https://www.fiero.nl/forum/Forum1/HTML/058236.html
newfiejeff
Report this Post12-31-2013 07:16 PM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
Am I right in saying that they will fit and be pretty close?
georgie
Report this Post12-31-2013 07:52 PM Click Here to See the Profile for georgieSend a Private Message to georgieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have 235/45R17 93H tire's on 17's an thay fit nice. Some tim's thay will rub, but only on a hard turn a round or big bump in the road.
newfiejeff
Report this Post01-01-2014 08:14 AM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post01-01-2014 10:30 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
What is the width of the wheel?
rogergarrison
Total ratings: 551
Report this Post01-01-2014 10:39 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
The points to check on rubbing are the fronts when turned all the way to lock, especially backing up. The rears check for the clearance at the spring/strut on the inside. Even if its just 1/4", thats enough. Not much you can do for the rears, but you can make a stop for the front to limit how far it turns before locking. I had 8x16s on my Ferrari kit and had to grind slightly on the lips of the front A arms to get 1/8" clearance.
newfiejeff
Report this Post01-02-2014 04:05 AM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
Indy84Pace
Report this Post01-03-2014 09:03 PM Click Here to See the Profile for Indy84PaceSend a Private Message to Indy84PaceEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have 18x8 w/38 mm offset running 225/40/18 on all four corners with no problems. They fit with stock brakes and ride height. I now run Eibach lowering springs and a c4 brake conversion with no issues. Plan on switching to a 9.5" rear this year with a 265/35/18.
jb1
Report this Post01-03-2014 09:28 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have 18x7.5 fr 205/40/18 38mm offset. and 18x8.75 rr 265/35/18 35mm offset
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a
Northstar Rebuild
