  Coolant System Debris Path
Coolant System Debris Path by smmilke
Started on: 12-29-2013 08:29 PM
Replies: 5 (201 views)
Last post by: fierosound on 12-31-2013 06:48 AM
smmilke
Report this Post12-29-2013 08:29 PM Click Here to See the Profile for smmilkeSend a Private Message to smmilkeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was having issues with the block heater in my 2.5 and after tearing things down due to a blown head gasket I found the heater blown halfway out of its hole! The heater was installed in the frost plug hole on the front of the block right about in the middle. All the retainer/washer/o-ring parts on the internal side of the tightening screw must be loose in the cooling system now. Any ideas on where the pieces might have traveled to, gotten stuck, or where I could open ports or hoses that might be hiding the parts?
Report this Post12-29-2013 09:16 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Look like This? What is in the block?
smmilke
Report this Post12-29-2013 09:21 PM Click Here to See the Profile for smmilkeSend a Private Message to smmilkeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I never saw exactly what it looked like before but I'm sure its the same style. All the parts threaded onto that screw in the middle are gone, other than a thin metal plate that must have been the first thing threaded on there. I never heard any chaos in the water pump and I have the head off now, haven't found the pieces in there..
fierosound
Total ratings: 287
Report this Post12-30-2013 07:17 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Coolant flows out the thermostat to the radiator, then back to the water pump which pushes it into the engine.
I think the parts would still be in the bottom of the block's passages.
Calgary time/temp
smmilke
Report this Post12-30-2013 01:53 PM Click Here to See the Profile for smmilkeSend a Private Message to smmilkeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is that right on the 2.5's? I was thinking anything that gets loose in the block would go through the water pump and then to the radiator. I'll take another look at the motor and see if I can get an inspection mirror to show me anything laying in the bottom of the block.
fierosound
Total ratings: 287
Report this Post12-31-2013 06:48 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Water pump always pushes coolant INTO the engine.
