  3800 supercharger pulley size...... 3.25 too small?
3800 supercharger pulley size...... 3.25 too small? by Flux
Started on: 12-23-2013 03:50 AM
Replies: 9 (683 views)
Last post by: Flux on 12-26-2013 07:57 PM
Flux
Report this Post12-23-2013 03:50 AM Click Here to See the Profile for FluxSend a Private Message to FluxEdit/Delete MessageReply w/QuoteDirect Link to This Post
mods are XP cam (and supporting valvetrain mods), headers, thermostat, plugs, N* TB, LQ4 MAF, and a base tune. this is on a series 3 engine with a gen v.
is the 3.25 pulley too much? how should I go about tuning this and scanning for KR when it's all put together? am I better of running a larger pulley with these mods? thanks
bmwguru
Total ratings: 131
Report this Post12-23-2013 05:50 AM Click Here to See the Profile for bmwguruClick Here to visit bmwguru's HomePageSend a Private Message to bmwguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Injectors?
revin
Total ratings: 234
Report this Post12-23-2013 08:25 AM Click Here to See the Profile for revinSend a Private Message to revinEdit/Delete MessageReply w/QuoteDirect Link to This Post
No IC? You should HEAR the KR without scanning.
[This message has been edited by revin (edited 12-23-2013).]
FIEROFLYER
Total ratings: 180
Report this Post12-23-2013 08:33 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Those mods on a series II would be ok but with the gen V SC I would say get an inter cooler to be safe and a good in car tune. Dan
darkhorizon
Total ratings: 451
Report this Post12-23-2013 10:20 AM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Probably fine. As mentioned it may be a good idea to look at 42# injectors but its most likely not a huge requirement with a big fuel pump.
Flux
Report this Post12-23-2013 04:32 PM Click Here to See the Profile for FluxSend a Private Message to FluxEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm using stock SIII injectors with an EP381 (?) fuel pump. Would I be better off running a 3.4 then? IC is out of budget right now
[This message has been edited by Flux (edited 12-23-2013).]
hnthomps
Total ratings: 51
Report this Post12-23-2013 05:18 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a similar engine (N* tv, VS cam, 3800 SC Series III engine, and an intercooler) and am currently running a 3.4 pulley with a conservative tune. The dyno indicates about 300 ft lbs of torque and around 300 HP at the wheels with no knock. I think that I could safely run a 3.0 pulley with this setup and have one in the basement but have not tried it out so far. You should have little (if any) knock with the 3.4 and a decent tune.
Nelson
MstangsBware
Total ratings: 459
Report this Post12-23-2013 11:50 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would say yes with just a base tune. Jump up to a 3.4 and start scanning and see what u come up with.
darkhorizon
Total ratings: 451
Report this Post12-24-2013 01:01 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
IC is not really needed.. we have made plenty of power on a 3.0/xp/gen5 before with the correct injectors and exhaust setup.
Flux
Report this Post12-26-2013 07:57 PM Click Here to See the Profile for FluxSend a Private Message to FluxEdit/Delete MessageReply w/QuoteDirect Link to This Post
well I think I will break in the clutch and valvetrain gear with the 3.8 pulley and then go get it tuned for a smaller one
