  wing/spoiler stand repair
wing/spoiler stand repair by E.Furgal
Started on: 12-17-2013 04:29 PM
Replies: 5 (279 views)
Last post by: pontiackid86 on 12-18-2013 02:34 AM
E.Furgal
Total ratings: 278
Report this Post12-17-2013 04:29 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
What would the best type glue(epoxy) to use to fix a cracked stand.. it's cracked near bottom and around the area the metal stud screws into.. no idea what these stands are made of to get a feel on the type epoxy would be the best.. it a '84 indy..
Fiero84Freak
Report this Post12-17-2013 06:09 PM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
If my memory serves me correctly as I have not had a Fiero's wing stands apart in a few years time the spoiler stands are made out of SMC, so repair procedures would be the same as if you were servicing any other SMC panel, meaning you could not use fiberglass or a polyester resin to properly fill the crack. Those could be used as a support on the backing part of the panel, but not to actually fix the crack. Someone can correct me if I'm wrong though on what it's made out of but again I believe it's SMC like the roof, hood, decklid, and rear body clip.
joeschuit
Report this Post12-17-2013 06:23 PM Click Here to See the Profile for joeschuitSend a Private Message to joeschuitEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've got a used set laying around that I'm not using. No cracks. PM me if you want them.
IMSA GT
Total ratings: 253
Report this Post12-17-2013 08:32 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe the only way to make this work is to use JB weld and glue the stud back in.
However, a little off topic.....if ANYONE has a set they can loan me for a little while...broken or not...please PM me. I am going to make new stock sized replacements but I need a set for the molds.
BrittB
Report this Post12-17-2013 08:46 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's what I would do as well, GRP replacements would be the way to go plus if you wanted a custom height stands you would have that option.
pontiackid86
Total ratings: 344
Report this Post12-18-2013 02:34 AM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have to remember how I did it but I ended up using some kind of drywall anchors with JB weld and Screw's to kind of rid mine up, worked Very well on my old 87, Sadly I don't have any with a stock spoiler anymore so I wont be of much help
