  Where to purchase ?
Where to purchase ? by Lou6t4gto
Started on: 12-06-2013 12:27 AM
Replies: 7 (342 views)
Last post by: Lou6t4gto on 12-09-2013 12:51 PM
Lou6t4gto
Report this Post12-06-2013 12:27 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where can I get a converted Fiero water neck for my 3800Sc ? Thanks
Total ratings: 207
Report this Post12-06-2013 07:58 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
You really dont need one, the stock 3800 housing works just fine.......
Lou6t4gto
Report this Post12-06-2013 12:49 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I WANT the" Fill point" to be Higher. thanks
Total ratings: 207
Report this Post12-06-2013 02:59 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I understand that, but........
The fill point is the overflow tank.
The initial fill can be performed with the 3800 t-stat and housing removed. There is an air bleed on the t-stat housing to burp the system of air.
Beyond the initial fill, the only place you need to add coolant is the overflow tank.
hookdonspeed
Total ratings: 131
Report this Post12-06-2013 04:03 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
i think bmwguru was selling them, send him a PM.
cmechmann
Report this Post12-06-2013 10:25 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
A lot off thermostats have a small, less than a 1/16, v cut in the inner separation plate. Many of the late model thermostats don't. For cars that seem to have a burp issue, I take an 1/8 drill bit and drill a small hole in the separation plate. The flat area between the thermal plate and the outer sealing ring. With that you don't need to remove the housing on initial fill. Open the bleeder on the stock 3800 housing, fill at radiator cap. Wait a little for the air to purge out and fill again. Start the car. While running, wait for the air to purge from the bleeder, close the bleeder. The water pump will "pull down" the coolant level from the radiator and "push up" the level in the engine. Top off the radiator. Reinstall cap and top off overflow
Because of the small hole in the separation plate, you don't need to wait for the thermostat to open. However, the coolant bypass hose from the intake to the timing cover must be functional.
I would also run the car, cool off, and top off again due to air trapped in heater circuit.
[This message has been edited by cmechmann (edited 12-06-2013).]
bmwguru
Total ratings: 131
Report this Post12-07-2013 05:09 AM Click Here to See the Profile for bmwguruClick Here to visit bmwguru's HomePageSend a Private Message to bmwguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
We sell them. It makes bleeding out the cooling system much easier than using the 3800 water neck. I would need to mod your housing as I am out of stock on them. We cut and TIG weld them and then pressure test them. Send me a pm if you are interested.
Dave
www.hausofguru.com
Lou6t4gto
Report this Post12-09-2013 12:51 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
unfortunately I "butchered up" the Fiero neck I had already. I guess I'll use an "inline" filler just off of the 3800 housing.
