  welding pipe to filler neck
welding pipe to filler neck by pdemondo
Started on: 12-01-2013 07:00 PM
Replies: 9 (496 views)
Last post by: RCR on 12-03-2013 06:53 AM
pdemondo
Report this Post12-01-2013 07:00 PM Click Here to See the Profile for pdemondoSend a Private Message to pdemondoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am using a 4 cyl thermostat housing on a 3.4 doch swap. I cut the flange off and I am trying to weld a section of 1 1/2" pipe to extend
the housing to clear the throttle cable.
I cannot get the weld to stick very well to the thermostat housing, only the pipe. I have read some posts where a few people did
weld to the housing. How did you do it?
Thanks for any help.
Boostdreamer
Total ratings: 98
Report this Post12-01-2013 08:39 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
What process are you using? TIG?
Jonathan
My '85 L67 Build Thread
pdemondo
Report this Post12-01-2013 08:43 PM Click Here to See the Profile for pdemondoSend a Private Message to pdemondoEdit/Delete MessageReply w/QuoteDirect Link to This Post
MIG without gas, rosin core wire.
Tha Driver
Total ratings: 204
Report this Post12-01-2013 11:57 PM Click Here to See the Profile for Tha DriverClick Here to visit Tha Driver's HomePageSend a Private Message to Tha DriverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Get some gas & regular wire. Will make a world of difference.
~ Paul
aka "Tha Driver"
Custom Fiberglass Parts
RCR
Total ratings: 102
Report this Post12-02-2013 12:01 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
FWIW, when I did mine ages ago for my 3800 swap, I brazed it.
Bob
jaskispyder
Total ratings: 205
Report this Post12-02-2013 12:04 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bob
x2
Or take it to a welder and have them do it. Shouldn't cost much.
pdemondo
Report this Post12-02-2013 06:32 PM Click Here to See the Profile for pdemondoSend a Private Message to pdemondoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bob
That makes sense. It did look like the joints were copper or brass.
Yeah, it might be easier to just take them to a shop for brazing.
Total ratings: 260
Report this Post12-02-2013 07:15 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have welded them to metal plates before, just need to make sure you stay away from any factory seams as they were brazed.
Khw
Total ratings: 134
Report this Post12-02-2013 11:16 PM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bob
That was my first thought "Braze it".
RCR
Total ratings: 102
Report this Post12-03-2013 06:53 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
If you're willing to try it, I used a little oxy/map gas rig I picked up at Home Depot. It's not very expensive and gets the job done. The tanks don't last long, but it works.
Bob
