  Does Timken Make A Rear Main Seal for 2.8?
Does Timken Make A Rear Main Seal for 2.8? by Boostdreamer
Started on: 11-23-2013 12:40 AM
Replies: 6 (247 views)
Last post by: Boostdreamer on 01-06-2014 01:43 PM
Boostdreamer
Total ratings: 98
Report this Post11-23-2013 12:40 AM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does Timken make a rear main seal for the 2.8 V6? Any idea what the part number is?
If not, what brand of seal would be my next best option?
Jonathan
steve308
Total ratings: 59
Report this Post11-23-2013 06:24 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Timkin.com has your answer.
Boostdreamer
Total ratings: 98
Report this Post11-23-2013 08:37 AM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I tried there first but there was no link to their seals. Only links to their bearings.
Jonathan
steve308
Total ratings: 59
Report this Post11-23-2013 09:43 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Your not looking in the correct place - Timkin.com - PDF catalog - seals page 487 - two listed or use the interchange with a competitors number.
PONTIAC - REAR DRIVE - Fiero (cont.)
5-SPEED MANUAL TRANSAXLE (cont.)
Input Shaft (cont.)
1988-1985 Isuzu
Seal (front) ..........................................................222835
Bearing Assy (front) ...........................................32206M
Kwik Slv (Opt Rpr) ........................................KWK99111
Bearing Assy (rear) ............................................30306M
Output Shaft
1988-1986 Getrag
Seal ........................................................................ 3543[2]
Kwik Slv (Opt Rpr) ........................................KWK99139[2]
1988-1985 Isuzu
Bearing Assy (RH) .............................................32206M
Set (LH) ................................................................. SET5
Selector Shaft Seal/Man. Shaft
1988-1985
Seal ........................................................................ 3667
CRANKSHAFT REAR SEAL
4 Cylinder
1988-1984 151/2.5L
Seal ........................................................................ 3698
6 Cylinder
1988-1985 173/2.8L 2nd design
Seal ......................................................................4307V
Seal PTFE H/D Opt. .............................................. 5273
Kwik Slv (Opt Rpr) ........................................KWK99298
1985 173/2.8L 1st design
Seal ........................................................................ 5210
TIMING COVER
4 Cylinder
1988-1984 151/2.5L
Seal ........................................................................ 9845
Kwik Slv (Opt Rpr) ........................................KWK99176
Harmonic Balancer
Sleeves .................................................................88176
6 Cylinder
1988-1985 173/2.8L
Harmonic Balancer
Boostdreamer
Total ratings: 98
Report this Post11-23-2013 10:25 AM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Timken 4307V. Thank you very much! Plus for your efforts!
Jonathan
[This message has been edited by Boostdreamer (edited 11-23-2013).]
FieroNate
Report this Post11-28-2013 12:03 PM Click Here to See the Profile for FieroNateClick Here to visit FieroNate's HomePageSend a Private Message to FieroNateEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think both national, federal mogul and victor make seals and gaskets. I've used main seals from federal mogul in the past. Be sure to clean the metal around the seal with a solvent like acetone, then use Permatex form-a-gasket 515 or 518 (one is non hardening) to seal the interface between the metal and seal. Works well in my experience.
[This message has been edited by FieroNate (edited 11-28-2013).]
Boostdreamer
Total ratings: 98
Report this Post01-06-2014 01:43 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just to follow up. That was the correct seal for the rear main. It went in very easily after being kept in the fridge for a week then in the freezer over night before installation. The original was difficult to get out. It came out in pieces. I may still have a slight leak but it is so much better than before. No regrets.
Jonathan
