There's a picture of the 88 and 86 C500 in this thread:
C500 The 1988 "F10" black wire is the same position as the 1986 "F0" dark green/white stripe wire
In 86 the "F0" (F10) wire turns on the v6 trunk mounted blower fan (not used on 4cyl) and the radiator fan when grounded.
If you ground it now (86 interior/88 rear harnesses) with the key on all the lights should work & the cooling fan should turn on, key off just the brake lights should work.
There are some differences in the two pictures (G7,G8,J9) but when I traced them through the schematics for a 4 cyl. they looked like they will work, the differences are for a GT.
[This message has been edited by AL68 (edited 11-17-2013).]
