  84 cradle swap into an 86?
84 cradle swap into an 86? by crashmydaytona
Started on: 11-06-2013 11:15 AM
Replies: 5 (445 views)
Last post by: Bloozberry on 11-06-2013 09:16 PM
crashmydaytona
Report this Post11-06-2013 11:15 AM Click Here to See the Profile for crashmydaytonaSend a Private Message to crashmydaytonaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If I purchased an 84 fiero with a 3800 sc swap done will I be able to drop the cradle and install it in my 86 gt? thanks
Total ratings: 202
Report this Post11-06-2013 12:02 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, the four major mounting points are all the same. Any changes that would have needed to be done to put a different engine / transmission in have obviously already been done too, so as far as bolting it up, it should be straight-forward.
tesmith66
Total ratings: 135
Report this Post11-06-2013 12:12 PM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
The only difference in the two cradles is the 85-87 units have extra holes for mounting the V6. Everything else is the same.
crashmydaytona
Report this Post11-06-2013 01:29 PM Click Here to See the Profile for crashmydaytonaSend a Private Message to crashmydaytonaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you that's what I needed to know. I appreciate the forum and all the help.
TONY_C
Report this Post11-06-2013 01:53 PM Click Here to See the Profile for TONY_CSend a Private Message to TONY_CEdit/Delete MessageReply w/QuoteDirect Link to This Post
The location of the C500 connector is different on the 84's. You will have to make some wires longer on the 86 longer to reach the connector. Also, the pinouts at the C500 connector are slightly different on the later cars due to the V6.
Bloozberry
Total ratings: 311
Report this Post11-06-2013 09:16 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
The location of the rear tie rod mounts on the cradle are different too. The cradle will still bolt right up but the '84's rear end bump steers more than later models because of it.
