  Generation II????
Generation II???? by newfiejeff
Started on: 10-31-2013 06:47 AM
Replies: 3 (80 views)
Last post by: tesmith66 on 10-31-2013 07:01 AM
newfiejeff
Report this Post10-31-2013 06:47 AM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
1986 2m4 5 speed
Just wondering when did the Generation II headlights get installed in the Fiero? I always thought that it was 87 up. I just seen a set on ebay saying to upgrade your car from an 84 to an 86 headlight system.
tesmith66
Total ratings: 135
Report this Post10-31-2013 06:56 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
You are correct. Gen II headlight system was on 87-88 Fiero. You can retrofit the system to 84-86 models.
[This message has been edited by tesmith66 (edited 10-31-2013).]
newfiejeff
Report this Post10-31-2013 06:57 AM Click Here to See the Profile for newfiejeffSend a Private Message to newfiejeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
So my fiero is a Gen 1 system? It seems like they ran some wires outside and hooked up a switch inside for the lights to go up at least not to go down.
tesmith66
Total ratings: 135
Report this Post10-31-2013 07:01 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
If yours is 84-86 and the motors are NOISY with big squared off knobs, it's the original Gen I system. Gen II has quieter motors with smaller, tapered knobs and an electronics module hidden behind the LH (I believe it's the LH side) front wheel well. Gen II system is far better than Gen I
1986 SE Aero coupe.
