  axle swap question
axle swap question by 86soon3.4
Started on: 10-14-2013 10:05 PM
Replies: 5 (396 views)
Last post by: jb1 on 10-15-2013 08:33 PM
86soon3.4
Report this Post10-14-2013 10:05 PM Click Here to See the Profile for 86soon3.4Send a Private Message to 86soon3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone ever cut new snap ring grooves in their axle shafts to shorten them up?
I am doing a V-8 swap and the drivers side axle is about 1/2 to 3/4" too long.
I think if I cut new snap ring grooves in further on the shaft I can achieve what I need.
I know they are hardened and will use a lathe and an abrasive cutting wheel.
Steve
trotterlg
Report this Post10-14-2013 11:11 PM Click Here to See the Profile for trotterlgSend a Private Message to trotterlgEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can't see any problem, you may want to cut the same amount off the end so it doesn't bind on anything, but if you have enough spline to go further in I would say to go for it. Larry
86soon3.4
Report this Post10-14-2013 11:14 PM Click Here to See the Profile for 86soon3.4Send a Private Message to 86soon3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I Will Attempt Tomorrow.
Steve
jb1
Report this Post10-15-2013 01:51 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes I had to cut new snap ring grooves and cut off 3/4" of the axle, pretty much exactly what you need.. was no problem at all..
87 GT
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a
My Build
86soon3.4
Report this Post10-15-2013 07:39 PM Click Here to See the Profile for 86soon3.4Send a Private Message to 86soon3.4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cut New Snap Ring Grooves In The Drivers Side Axle Shaft And
Removed 1/4 To 1/2" From Each End.
It Turned Out Perfect!
Steve
jb1
Report this Post10-15-2013 08:33 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
87 GT
86GT 3800 n/a
My Build
