  A/C goes warm when going up a hill and other high engine loads.
A/C goes warm when going up a hill and other high engine loads. by RACE
Started on: 08-26-2013 04:07 PM
Replies: 27 (513 views)
Last post by: RACE on 09-10-2013 12:10 AM
RACE
Total ratings: 157
Report this Post08-26-2013 04:07 PM Click Here to See the Profile for RACEClick Here to visit RACE's HomePageSend a Private Message to RACEEdit/Delete MessageReply w/QuoteDirect Link to This Post
A/C goes warm when going up a hill and other high engine loads. If anyone else has had this issue and has corrected it please let me know how you fixed it. I have the 2.5L automatic if that helps.
I have read that this can be normal for a lot of cars but the threshold of this happening seems to happen far too easilly. If you know of a way to adjust it please let me know that too. Thank you.
[This message has been edited by RACE (edited 08-26-2013).]
WICKEDWILDFIERO
Report this Post08-26-2013 05:10 PM Click Here to See the Profile for WICKEDWILDFIEROSend a Private Message to WICKEDWILDFIEROEdit/Delete MessageReply w/QuoteDirect Link to This Post
RACE...... You probably are losing vacuum to the HVAC controls.
RWDPLZ
Total ratings: 306
Report this Post08-26-2013 05:51 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope, Fiero's don't have vacuum AC controls. Are you at full throttle when this happens? IIRC the computer turns off the compressor at full throttle. Also, what year car?
RACE
Total ratings: 157
Report this Post08-26-2013 06:07 PM Click Here to See the Profile for RACEClick Here to visit RACE's HomePageSend a Private Message to RACEEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's an 87. It happens long before full throttle. On a straight road today the air con was really cold at 62 mph but at 70 mpg it got warm inside. I suspect that there is some type of vacuum cutout somewhere.
Total ratings: 260
Report this Post08-26-2013 06:14 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The ecm might turn the A/C off when it goes into power enrichment mode, or above a certain RPM
Tom Slick
Report this Post08-26-2013 06:34 PM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
really?
my A/C goes warm after about 30 minutes of highway driving.
thanks
Report this Post08-26-2013 06:51 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The computer gets a signal from the MAP sensor all the time, but I don't know what is in the software. It would be very easy to stop the compressor if the vacuum goes down...or is it up?...in the engine. This could be an indication that your engine is not making the power it used to make. Maybe a simple tune up would fix this.
RACE
Total ratings: 157
Report this Post08-26-2013 07:50 PM Click Here to See the Profile for RACEClick Here to visit RACE's HomePageSend a Private Message to RACEEdit/Delete MessageReply w/QuoteDirect Link to This Post
The engine is in good tune. My exhaust is old and I suspect that the cat may not be as open as it used to be but even so, it shouldn't cut out my a/c that early.
Total ratings: 260
Report this Post08-26-2013 07:59 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The ground for the AC clutch relay terminates at the ECM. This gives the ECM the ability to drop the ground and turn off the A/C. Normally its stated this is to turn it off at WOT, to help protect the compressor, but who really knows how it is handled with the 4cyl. Since the 4cly isn't blessed with excess power, it may disable the A/C sooner to allow it to put more power to the wheels under other high load conditions that might not be WOT.
Total ratings: 260
Report this Post08-26-2013 08:11 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Aug 2003
Originally posted by Tom Slick:
really?
thanks
I am not overly impressed with the LS4 compressor with a variable orifice. Its cool and will keep you from sweating, but I wouldn't call it good. I though something was wrong till I looked it up in the service manual. The maximum vent temps for ambient temps/humidity are listed in a chart. On a 86-95 degree day, here are the max temps based on humidity:
Below 30%: 59 degrees
30-50%: 63 degrees
Above 50%: 66 degrees
96-105 degree ambient temp:
Below 20%: 64 degrees
20-40%: 66 degrees
Above 40%: 70 degrees
RACE
Total ratings: 157
Report this Post08-26-2013 08:12 PM Click Here to See the Profile for RACEClick Here to visit RACE's HomePageSend a Private Message to RACEEdit/Delete MessageReply w/QuoteDirect Link to This Post
The best thing to do then is to get rid of the 4 cylinder then. ; ) That will happen eventually but its starting to sound like I will have have to live with it the way it is for now. I get better mileage at 62mph anyway.
If its based off of manifold pressure and not WOT then a vacuum leak could potentially create a premature wide open intake absolute pressure. My cruise control has never worked. Maybe its time to look into a possible leak in that system.
Thanks guys
TopNotch
Total ratings: 60
Report this Post08-26-2013 09:47 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
On the 87 and 88 4-cylinder, the ECM cuts out the AC at full throttle.
Tom Slick
Report this Post08-26-2013 09:50 PM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
30-50%: 63 degrees
20-40%: 66 degrees
sorry guru, the A/C problem is on my 2.8 Formula.
I ask Ryan about using the variable orifice tube on my LS4 he said it was not needed when using the LS4 A/C compressor.
I forgot the reason.
yeah, those temps you listed wouldn't work here in Texas.
i'll have to get a temp gauge on my vents and see how they compare to the ones you listed.
chetw77cruiser
Report this Post08-26-2013 10:23 PM Click Here to See the Profile for chetw77cruiserSend a Private Message to chetw77cruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 87 2.5 does kill the a/c comp at about 4600 RPM but unknown on throttle position. If it is like other setups, usually 75% throttle or above will disengage the compressor. Funny thing is, fuel cut is at about 5600 RPM.
Another thing to consider is a slipping compressor clutch. Slipping at normal operating speeds may not be noticeable, but while accelerating and higher RPM runs, the clutch can slip if worn or the air gap is not set correctly. I would have to say the clutch is worn.
Fieroguru, if this is the stock LS4 a/c compressor, I believe that it is of the variable displacement design. These work best with a fixed orifice tube.
[This message has been edited by chetw77cruiser (edited 08-26-2013).]
RACE
Total ratings: 157
Report this Post08-26-2013 11:31 PM Click Here to See the Profile for RACEClick Here to visit RACE's HomePageSend a Private Message to RACEEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a brand new compressor so really dont think that its slipping. Thee vent temp is 42 degrees when it's not cutting out. It's air colder than I thought it would have been. I'm not even sure if that's a good thing for the system.
Total ratings: 291
Report this Post08-27-2013 12:07 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking at a couple 2.8 chips the A/C cutoff is programmed at 98.83%. There is nothing else listed that I see to turn off the A/C.
Tom Slick
Report this Post08-27-2013 06:31 AM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
That's the answer Ryan gave me about the LS4 compressor.
masospaghetti
Report this Post08-27-2013 08:35 AM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used to have a 96 Camaro with the 3800, the compressor shutoff was way before WOT. Felt like maybe 50-60%. I guess this was to preserve the throttle response because of the car's sporty intentions.
Not sure if the 4-cyl Fiero does the same thing.
Total ratings: 154
Report this Post08-27-2013 09:06 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Something you can do to keep the cabin cooler is to run the system on MAX. This closes the door for outside air intake and recirculates the inside air. Rather than trying to heat 85 degree outside air, you start to re-cool air that may be in the 70's. Works like your home AC. Keep the windows and doors closed and your house stays cooler. Running the AC on NORM brings in the outside air, including some of the heated air from the radiator, which can pass around each side of the front compartment seal, along the fenders. Some people think that the MAX position keeps the compressor on all the time, but that's not the case. It cycles the same as when set at NORM.
masospaghetti
Report this Post08-27-2013 09:11 AM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
MAX will actually run the compressor less once steady state is reached. Once the air becomes sufficiently cooled, the pressure on the low side of the system will drop enough to trip the low pressure switch, and the compressor will begin to cycle.
Marvin McInnis
Total ratings: 227
Report this Post08-27-2013 10:05 AM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
No. The only thing that could cause that would be a disconnect between the intake manifold and the MAP sensor. A manifold vacuum leak has virtually no effect while driving, except at or near fully closed throttle. Think about it. While driving you will automatically (and unconsciously) compensate for any vacuum leak by reducing the throttle slightly. (It may help to think of the throttle itself is a big, driver-controlled vacuum leak.)
[This message has been edited by Marvin McInnis (edited 08-27-2013).]
Ray_and_kevin
Report this Post08-27-2013 01:17 PM Click Here to See the Profile for Ray_and_kevinSend a Private Message to Ray_and_kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are three things that will cause the compressor to shut off:
1) ECM at high throttle. I always thought it was for performance/safety too, but it does it at basically wide open throttle more or less.
2) Low refrigerant pressure. If you do not have enough, the compressor will draw down the pressure and the switch will open. This is the switch on the canister in the front trunk.
3) High refrigerant pressure. Not sure how this one would happen, but it is a safety feature.
Of course, the opinions of a slipping clutch are on the money. If the clutch is powered and you get warm air, then the clutch is not holding.
All the ways to find out which one it is are a little dicey since it happens while driving. You need to connect to the wires of each switch and see which one opens up. A small light bulb across the switch will illuminate if the switch opens. It is easiest to test the switch in the front trunk since you can bring test wires through all the seals in front. Don't have a wiring diagram here at work, but the ECM is likely to be either at the top of the chain or the bottom. That makes it pretty easy to see if it is the one doing the cut out.
You can probably tell pretty quickly if it is the low pressure switch by just putting a gauge on the low pressure side of the cannister. Have someone rev up the engine while you watch the pressure. You will for sure hear it if the switch opens. You can borrow a gauge from AutoZone. You pay for the gauge and then get a refund when you return it intact.
Marvin McInnis
Total ratings: 227
Report this Post08-27-2013 03:08 PM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Two ways immediately come to mind:
3a) Blockage somewhere in the refrigerant circuit ... e.g. a plugged orifice tube.
3b) Insufficient cooling airflow through the condenser ... e.g. sitting at a stop with the radiator fan inoperative; it doesn't take long.
Report this Post08-27-2013 04:13 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Low refrigerant pressure can do this? That seems the most likely reason.
dobey
Total ratings: 371
Report this Post08-27-2013 04:40 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was just about to reply "are you sure your system is fully charged with right amount of oil" as the probable cause.
Chelo Fiero
Report this Post08-27-2013 05:40 PM Click Here to See the Profile for Chelo FieroClick Here to visit Chelo Fiero's HomePageSend a Private Message to Chelo FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
An overheating coolant will cause that, some times the headgasket start to fail only on high rpm, or heavy loads, increasing the temp of the refrigerant at the radiator and causing the high preasure switch to shut off.. Even if you don't notice any coolant leaks, it may be compression or exhaust going to the coolant passage.
f85gtron
Report this Post08-27-2013 05:58 PM Click Here to See the Profile for f85gtronSend a Private Message to f85gtronEdit/Delete MessageReply w/QuoteDirect Link to This Post
My red herring..... Check the TPS for smooth ohms and then voltage. The ecm may think your mashing the go fast juicer all the way.....when your not. It probably isn't the right answer, but I thought i'd throw something in here anyway!
RACE
Total ratings: 157
Report this Post09-10-2013 12:10 AM Click Here to See the Profile for RACEClick Here to visit RACE's HomePageSend a Private Message to RACEEdit/Delete MessageReply w/QuoteDirect Link to This Post
As far as hot coolant goes I don't think that will ever be an issue. I have already installed a 3 core aluminum radiator in preparation for an eventual engine swap. The needle never moves. I'll check on some of the things that you have recommended and let you know if anything changes. Thanks guys.
