  auto to manual parts checklist
auto to manual parts checklist by Ac Fiero
Started on: 08-20-2013 08:43 AM
Replies: 2 (206 views)
Last post by: Ac Fiero on 08-20-2013 05:05 PM
Ac Fiero
Report this Post08-20-2013 08:43 AM Click Here to See the Profile for Ac FieroSend a Private Message to Ac FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
im going to be putting a 4 speed in my 86 gt auto 3.2 soon. i have an 84 with a 4 speed parts car laying around. a local yard has a muncie with the reinforced case that i want to buy. its from a cavalier. is that compatible? can i use the trans mounts and axles from my 84? do i need to put different wheel hubs on or can i stick with the ones currently on my 86? what flywheel is correct for the 3.2? im pretty sure the clutch pedal, master, slave and cables will work from my 84 but i could be wrong. id like to make sure i have everything i need before i start. thanks in advance
Anson Craig
FIEROFLYER
Total ratings: 180
Report this Post08-20-2013 09:08 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
If the Cavalier tranny is the 5 speed getrag you will need a Fiero 5 speed shifter, cables and either buy Rodneys kit or make one for the shifter cable brackets at the tranny end and tranny mounts. For the flywheel basically 88 and newer 60 degree V6 engines use a neutrally balanced flywheel and 87 and older is a balanced one so depends on what year engine you have. With stock axles your stock hubs fit fine and you will most likely need a different slave for the cav tranny. Dan
[This message has been edited by FIEROFLYER (edited 08-20-2013).]
Ac Fiero
Report this Post08-20-2013 05:05 PM Click Here to See the Profile for Ac FieroSend a Private Message to Ac FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok so i got the 4 speed Muncie from the cavalier. Axles from an 84 se will work with this then correct?
also, will my selector cable bracket from my 84 work on the transmission from an 86?
[This message has been edited by Ac Fiero (edited 08-21-2013).]
