  Body Fabricatition. A side scoop RRIM homade. (Page 1)
Body Fabricatition. A side scoop RRIM homade. by hercimer01
Started on: 04-01-2012 07:57 PM
Replies: 57 (4350 views)
Last post by: unboundmo on 04-18-2019 09:54 PM
hercimer01
Report this Post04-01-2012 07:57 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just asked Cliff to put this in the Construction Zone. So it may move. FYI.
I made a side scoop today. I used 3M 04247 Duramix. The quarter panels are RRIM and the material used to fill in was RIM from an old bumper cover .
I did the pass. side first and forgot to get a pic of the layout. I will post he driver side when I do it.
I didn't use the mixer tip for every application. It saves material.
88 formula 3.4L 4t60 swap
[This message has been edited by hercimer01 (edited 06-01-2012).]
jaredmurray88
Report this Post04-01-2012 09:33 PM Click Here to See the Profile for jaredmurray88Send a Private Message to jaredmurray88Edit/Delete MessageReply w/QuoteDirect Link to This Post
how do you plan on routing the air box on drivers side
"Speed costs money. How fast do you wanna go?"
hercimer01
Report this Post04-01-2012 09:41 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I plan to do the driver side cut out the same shape. I'll have to do some filling in where the original scoop is. This is a L67 swap. I don't think I'll have to do any ducting from the scoop to the filter.
hercimer01
Report this Post04-02-2012 02:42 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
You mean this?
jaredmurray88
Report this Post04-02-2012 05:58 AM Click Here to See the Profile for jaredmurray88Send a Private Message to jaredmurray88Edit/Delete MessageReply w/QuoteDirect Link to This Post
is that dryer ducting? does that realy work? i meant the scoop its self but you gave me an idea for my v8 swap intake setup lol
hercimer01
Report this Post04-02-2012 10:35 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by hercimer01 (edited 04-02-2012).]
jaredmurray88
Report this Post04-02-2012 12:31 PM Click Here to See the Profile for jaredmurray88Send a Private Message to jaredmurray88Edit/Delete MessageReply w/QuoteDirect Link to This Post
sweet i got some metal dryer duct laying around. never thought of that lol cool and cheap fix. jw how much was that type of filter?
hercimer01
Report this Post04-02-2012 12:52 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Autozone. Like around $30.00?
jaredmurray88
Report this Post04-02-2012 01:11 PM Click Here to See the Profile for jaredmurray88Send a Private Message to jaredmurray88Edit/Delete MessageReply w/QuoteDirect Link to This Post
is that where the duramix is from too? is that any better than the auto mix or same thing?
Sourmug
Total ratings: 144
Report this Post04-02-2012 01:30 PM Click Here to See the Profile for SourmugSend a Private Message to SourmugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a comment about the drain pipe used for the intake. The corrugations cause a fair bit of static resistance in the airstream, coupled with the U-bend at the filter this will probably negate much of any benefit that you were hoping to see.
Just my $0.02
Nolan
[This message has been edited by Sourmug (edited 04-02-2012).]
hercimer01
Report this Post04-02-2012 02:03 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've only driven the car this way once for a test drive. I was wondering how it would effect performance.
hercimer01
Report this Post04-04-2012 10:56 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I fouund this, it says it will do the same thing as the 4247. This is Evercoat 887, you get more in a tube and it cost a whole lot less and a regular caulk gun will work with application. I will be doing the driver side in the next couple of days.
Edit: this didn't work. It's to soft I had to go back to the 3M 4247. Maybe the Evercoat 6101 will work but I 'm done trying new products for now.
[This message has been edited by hercimer01 (edited 04-07-2012).]
jaredmurray88
Report this Post04-04-2012 03:22 PM Click Here to See the Profile for jaredmurray88Send a Private Message to jaredmurray88Edit/Delete MessageReply w/QuoteDirect Link to This Post
where did you find the products? very interesting process cant wait to see result
qwikgta
Total ratings: 84
Report this Post04-04-2012 04:54 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
EVERCOAT. Best stuff out there.
http://www.evercoat.com/products.aspx
Rob
jaredmurray88
Report this Post04-05-2012 05:02 PM Click Here to See the Profile for jaredmurray88Send a Private Message to jaredmurray88Edit/Delete MessageReply w/QuoteDirect Link to This Post
is there a retailer that has this or is it off the manufacturer?
hercimer01
Report this Post04-06-2012 01:09 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
You can get it at your local automotive paint store or order it through the web.
hercimer01
Report this Post04-06-2012 01:24 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
Member since Mar 2008
Now starting on the driver side,I bought an extra lower quarter for filler material. I cut out the old air scoop and cut a filler blank.
Grind all the bonding surfaces with 80 grit and taper the edges. Leave a gap so the epoxy will get in between all the edges and bond well. Build the epoxy up on the back side a little for strength.
Don't get to carried away on the front side with the epoxy cuz it will have to be ground off smooth. This is why you want the edges tapered a little so the epoxy will get in there good.
I will do some later.
freedom0226
Report this Post04-06-2012 01:19 PM Click Here to See the Profile for freedom0226Send a Private Message to freedom0226Edit/Delete MessageReply w/QuoteDirect Link to This Post
wanna see more
hercimer01
Report this Post04-06-2012 02:08 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
This weekend.
Idaho_Fiero
Report this Post04-06-2012 07:49 PM Click Here to See the Profile for Idaho_FieroSend a Private Message to Idaho_FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
oh, this is getting good. Awesome job so far. Waiting for more.
Wes
hercimer01
Report this Post04-07-2012 03:35 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
Report this Post04-07-2012 03:41 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I used the Evercoat Maxim on this part trying to save money and of course It was a waste of money. Fortunately the guy at the paint shop refunded my money and sold me the 3M 4247 instead. He did recommend the Evecoat afterall.
The Evercoat Maxim cured to like a rubber consistency. That wont work here, the 3M 4247 is more like a plastic weld and acts like the RRIM after its cured.
hercimer01
Report this Post04-07-2012 03:49 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
( the sound of a D.A. in the background.)
hercimer01
Report this Post04-07-2012 04:56 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
OK Thats much better now.
CrazyDragn
Report this Post04-07-2012 10:02 PM Click Here to See the Profile for CrazyDragnSend a Private Message to CrazyDragnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice work, keep us posted
hercimer01
Report this Post04-07-2012 10:15 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's all I could get done today. I sold my 88 Formula today. I'm kinda drained,. I'll try to get more done tomorrow. Thanks for the compliments.
hercimer01
Report this Post04-08-2012 08:51 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
Report this Post04-09-2012 01:40 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
weloveour86se
Total ratings: 75
Report this Post04-09-2012 10:50 AM Click Here to See the Profile for weloveour86seSend a Private Message to weloveour86seEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice work!
What did you use to make your cuts with? How'd you keep your cuts neat? Maybe I missed it.
Thanks for sharing! This will make it easier for the laymen to make their own scoops in any shape they might want. No offense to whoevers making and selling them but $299.00 for something we can make on our own?
Plusses for you!
hercimer01
Report this Post04-09-2012 12:55 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by weloveour86se:
Nice work!
Plusses for you!
I used an air saw from harbor freight.
http://www.harborfreight.co...metal-saw-91753.html
There is a-lot of work in those side scoops for $299.00, they are worth it. Im just on a budget and can make things. These scoops wont have lines that flow as well as the fiberglass ones but for the cost I can deal with that.
I did a-lot of searching on how to work with the RRIM material (adhesives) some people said to use Evercoat Vette Panel Adhesive but the Evercoat Fiber Tech had the same rating as the Vette panel adhesive except stronger. I used the 3M 04247 super fast adhesive and its rated for RRIM and cures in 5 or 10 minutes.
hercimer01
Report this Post04-09-2012 12:59 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
I still have to reinforce the edges of the scoop opening and shape and fill the curves.
jaredmurray88
Report this Post04-09-2012 03:17 PM Click Here to See the Profile for jaredmurray88Send a Private Message to jaredmurray88Edit/Delete MessageReply w/QuoteDirect Link to This Post
man i hope this goes to another page soon my phone wont load any more pics
Tha Driver
Total ratings: 204
Report this Post04-09-2012 06:12 PM Click Here to See the Profile for Tha DriverClick Here to visit Tha Driver's HomePageSend a Private Message to Tha DriverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah you don't want to use SMC adhesive/filler on RRIM.
I would suggest adding a small flange to the thin outside edge to give it a more finished look.
~ Paul
aka "Tha Driver"
Custom Fiberglass Parts
hercimer01
Report this Post05-05-2012 02:46 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had to do alot of shaping with the epoxy. Now I can fill the minor stuff with filler.
I pulled the defrost cover off an old dash I had that was no good. The honeycomb looks great behind the opening. Maybe i can get them primed this weekend.
hercimer01
Report this Post05-05-2012 02:51 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
~ Paul
aka "Tha Driver"
I added a stiffener strip to the outside edge like you said. Thanks.
Tha Driver
Total ratings: 204
Report this Post05-05-2012 06:12 AM Click Here to See the Profile for Tha DriverClick Here to visit Tha Driver's HomePageSend a Private Message to Tha DriverEdit/Delete MessageReply w/QuoteDirect Link to This Post
That looks great, as does the whole vent. You might want to open it up more in the top, if your screen is long enough.
~ Paul
aka "Tha Driver"
Pete Matos
Report this Post05-05-2012 10:33 AM Click Here to See the Profile for Pete MatosSend a Private Message to Pete MatosEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey man that looks really freakin' good. I love home made jobs. I agree with the driver tho that you should cut just a little more opening at the top and it would be perfect. Maybe I need to try something like that on my new 85 GT. Still up in the air about the style of vent I am going with tho I may want the imsa style square vents. Nice work man...peace
Pete
hercimer01
Report this Post05-07-2012 02:49 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys for the compliments.
I did open up the top of the openings a little.
I forgot to get some pics of the driver side but it looks good too.
Fierostarvin
Report this Post05-07-2012 12:07 PM Click Here to See the Profile for FierostarvinSend a Private Message to FierostarvinEdit/Delete MessageReply w/QuoteDirect Link to This Post
They look good, thanks for posting
a_bartle
Report this Post05-07-2012 01:08 PM Click Here to See the Profile for a_bartleSend a Private Message to a_bartleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, can't wait to see the finished (painted) product. Really nice work!
