  Inspect NEW Oil Before Buying
Inspect NEW Oil Before Buying by Dennis LaGrua
Started on: 07-16-2025 04:19 AM
Replies: 11 (191 views)
Last post by: Stingray92 on 07-17-2025 10:08 PM
Total ratings: 328
Report this Post07-16-2025 04:19 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just thought that I'd pass this on as I just found the latest scam. I frequently buy Mobil 1 oil at Walmart. On the last purchased on a whim I decided to check the oil when I gut back to the car in the parking lot by taking off the cap of the 5 liter containers. Took off the cap to one container there was no seal and the OIL was black. Poured a few drops out into the cap and the oil was dirty used oil. Took the cap off the second contain and the foil seal was still there. Pulled off the "seal" and that container was full of used dirty used oil as well. The thief apparently filled the container with his used oil and took the time to glue the metal seal back on. Took both bottles back to the store with the receipt and customer service said " we are seeing more of this lately" They gave me credit for the purchase.
I hate to say it but now we need to check new bottles of oil before we buy. Sadly there seems to be no end to the scammer schemes.
[This message has been edited by Dennis LaGrua (edited 07-16-2025).]
Total ratings: 230
Report this Post07-16-2025 07:19 AM Click Here to See the Profile for blackramsSend a Private Message to blackramsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like an "Inside Job". Walmart needs to be watching it's own employees.
Rams
Craig71188
Report this Post07-16-2025 07:45 AM Click Here to See the Profile for Craig71188Send a Private Message to Craig71188Edit/Delete MessageReply w/QuoteDirect Link to This Post
Buy oil, change oil, return old oil in NEW jug. NO ONE in returns checks anything. Also went to Walmart to get an AC Delco filter. On a whim, opened the box - Fram inside. Two more just the same. Just so happens the Fram is several dollars cheaper.
People just suck anymore....
css9450
Total ratings: 87
Report this Post07-16-2025 08:03 AM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
Walmart's generous return policy invites abuses such as these. Apparently they don't check anything that comes back in as a return.
The used oil thing is common. Seems to me like it should be an obvious scam to spot; I mean if someone buys the wrong grade of oil and needs to return it and get the correct grade, that is understandable, but in what honest scenario does someone buy oil and suddenly change their mind and need to return it? It's not like the people who buy a fancy suit to wear to an interview and then return it the next day. The employees ought to be able to spot that one a mile away.
The only time it happened to me was once when I bought a container of either power steering fluid or brake fluid - I don't remember which - and the seal was opened and about 1/4 of the bottle was gone. My fault I guess for not noticing. I bet someone filled their reservoir out in the parking lot and returned the rest of it.
Larryinkc
Report this Post07-16-2025 08:17 AM Click Here to See the Profile for LarryinkcSend a Private Message to LarryinkcEdit/Delete MessageReply w/QuoteDirect Link to This Post
I buy oil online from Walmart or Amazon, three 1 gallon jugs at a time. The price is lower and shipping is free, quick delivery also. I use Pennzoil Ultra Platinum which Walmart usually does not have in stock at the store anyway
Vintage-Nut
Report this Post07-16-2025 09:48 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, it is true! Morals are in the toilet....
css9450:
For me, I always buy oil from trusted local auto part stores and never been scammed....
Total ratings: 328
Report this Post07-16-2025 12:07 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thats good and it solves one problem but last year they caught a couple of towel heads at a station in my area that were watering down the gas,
Total ratings: 202
Report this Post07-16-2025 05:07 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Happened to me too. I bought a 5-Quart container of Royal Purple oil, and it was someone's used oil. I brought it back and they were totally ok with it, but only because they knew me and I spend so much money there.
Craig71188
Report this Post07-17-2025 07:21 AM Click Here to See the Profile for Craig71188Send a Private Message to Craig71188Edit/Delete MessageReply w/QuoteDirect Link to This Post
You've been lucky. I work with many of the warehouses that supply local auto parts stores. Most have minimal checks on returned items and there are numerous unscrupulous store owners who will return used parts in new boxes when times get tight. Oil is not typically a problem area - but hard parts...oh, yea.
Vintage-Nut
Report this Post07-17-2025 09:39 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Craig71188:
You're correct, the topic is "Inspect NEW Oil Before Buying" and not parts....
G-Man
Report this Post07-17-2025 04:19 PM Click Here to See the Profile for G-ManSend a Private Message to G-ManEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bought a DeWalt drill/impact driver set at Lowe's once. Opened it and found a couple of worn out Milwaukee drills and two pairs of shoes, also heavily worn.
They had thrown the shoes in the box as packing to keep the drills from sliding around and tipping off the counter person something wasn't right. Or maybe they already knew what was going on, who knows?
The person helping me switched out the return for another set and I checked the contents before heading back out.
This was one of the most ridiculous things I'd ever seen so I couldn't help but laugh.
Gary
Stingray92
Report this Post07-17-2025 10:08 PM Click Here to See the Profile for Stingray92Send a Private Message to Stingray92Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sure are some !ow life's out there...
How does a fortune 500 company skate by on such ridiculous carelessness?
I had about 4-5 gallons to recycle a few years back, was turned away because it was too much. A guy in line said I'll take it.
I don't shop at junkmart! maybe back when they 1st were spreading ok but now
