would your use case be for drag or track? Im thinking you will have to tub out the rear to get wide enough tires to hook up. The Plaid is 4,766 lbs Im not sure how much weight you would add to the 2,789lb Fiero minus engine and trans cooling fuel tank you would be at what 2100? Then you add back the front diff and motor and the two rear motors plus a battery pack and the controller electronics. I think the tesla 85 kWh battery pack weighs 1,200 lbs so that would put you up at 3300lbs if you decided to use that. I cant remember but I want to say 3300 was the GVWR for the stock Fiero? The Ogre will correct me in a moment. So you will need to probably stiffen the chassis and suspension and use better rated tires and some bigger brakes probably have to use tesla brakes anyway and hopefully you get some regen with the motors?
just some random ramblings
