| quote | Originally posted by Fie Ro: You have a good point here.
I remember I installed a plastic guard on the front edge and just took a look at the situation:
| CLICK FOR FULL SIZE |
However it does nothing when the door is lifted.
Here now I can see the original "bearing" plates on the door, the buckets don't use them at all:
The bucket edges push up outside of the door's bracket. Thin metal edge pushing into flat plastic is indeed not good.
I think I will have to add some sort of plastic guard to the bucket top sides and some flat reenforcement under the doors where it slides. (Then add headlight grease lol) |
Ok idea but likely the "wrong" fix.
Doors have bearing strips for the lift bearing point to load w/o hitting other spots.
OE HL Trim that wraps around the "bucket" has secondary "bearing points" (in blue) that 1 both or none contacts the door that near full open. You see it on right side just right of main "bearing." Left side trim barely touches the door when full open.
You can't take a picture w/ most normal cameras w/o having some parallax problems. I lined up right side to show both points where hits the door. (Hood open, lift part way up.)
HL Trim and Door Strips are likely Polypropylene that act like "Teflon" in this use. Door bottom and lift are glass reinforce plastic of some type. PP does wear but enough "lube power" to wear very slowly in normal operation.
At least you tried. Most do nothing and many wreck the door bottom.
Worse. Many use Fog/Driving lights to replace HL in low lift and other setups and blind everyone and is crap even for the driver. Is why the old "munson no door upgrade" use real sealed beam HL bulbs but still cause many problems and some had to mod or remove that.
