  Need 4.9 Expert (Page 1)
Need 4.9 Expert by fierofool
Started on: 06-13-2021 06:33 PM
Replies: 106 (2159 views)
Last post by: Raydar on 10-21-2021 08:24 PM
Report this Post06-13-2021 06:33 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking for a 4.9 expert within reasonable distance of Atlanta, Ga. I already know about The Fiero Factory. That's where the original installation was done. Not knocking them, but original owner says it's never been right. Now, it's worse than ever.
J Gunsett
Report this Post06-14-2021 10:07 AM Click Here to See the Profile for J GunsettClick Here to visit J Gunsett's HomePageSend a Private Message to J GunsettEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tell us what is wrong and the problems you are having. Has it had any mods done to the engine? Stick or auto?
Jack
Report this Post06-14-2021 11:47 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've done this swap and am familiar with them. While not near Atlanta, I will be at Carlisle and would be glad to chat about solutions. While I wear a name badge, if you wish to track me down, I will PM my cell number to you. Feel free to give me a buzz. Don't claim to be an expert but have done computer controlled engine work for many years. If you can do an ECM scan beforehand that would help.
[This message has been edited by Dennis LaGrua (edited 06-14-2021).]
Report this Post06-14-2021 05:26 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll be at Carlisle, too. I wanted to meet you but missed you 2 years ago. If I can't find you, I'll have the "C8 Prototype" and should be close by.
The car is a Formula with manual trans and belongs to a club member who, after 2 years, has become so disgusted that he's given up. I'll have to get a listing of everything done and see if I can get a scan copy.
Jack, the car has had every sensor on it replaced. The distributor has been replaced with a new one. The ECM was replaced. No change, so the original was put back in. The injectors were replaced because the car had been running extremely rich. That problem has been mostly resolved.
The engine runs well when the ECM is jumpered. Set the base timing and remove the jumper and it runs lousy.
Prior to the member acquiring the car, the original owner had been driving it. I believe for a number of years. It began randomly running on 4 cylinders, then 8. No common happening to make it begin missing on 4, then back to 8. We found a fuse block mounted on the right strut tower had a bad contact and one of the injector fuses was losing contact from time to time. That fuse block has been replaced and a shield installed over it to keep out water. Now, it runs on all 8.
Another problem is that it continually throws the belt. The battery has to be removed to replace it. It was found that the idler/tensioner was bad and was replaced. That didn't fix the problem.
Dennis, would you be open to chatting with the owner? I'm just trying to find a solution for him.
Report this Post06-14-2021 05:53 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Jan 2002
Here's the list. Can't get a scan at this time.
ECM changed 3 times.
New Distributor
New injectors
New Plugs
New TPS
Continuity checked between all sensors and ECM
Grounds checked
ICM and Hall Effect sensors swapped around
Mechanical timing verified to be correct
New fuel pressure regulator
New EGR valve
No ECM has thrown any codes
New O-2 sensor
No check engine light when shorting A&B
Firing order verified to be correct
Set timing to 10-12 BTC with A&B shorted, runs good
Pull jumper and it begins missing, coughing, sputtering
Runs a little rich, but not choking anyone out of the shop like it was a year ago.
He's seriously about to confirm the saying "They all catch fire".
[This message has been edited by fierofool (edited 06-14-2021).]
Report this Post06-14-2021 08:09 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Judging by what you have indicated. Check to make sure that pin C9 of the ECM is connected to 12V ignition. It should be the Lt.blue/orange lead. If you do not read 12V on C9 (ignition on) the ECM will not go into closed loop and operate correctly. I recommend taking out the VOM meter to measure the voltage there.
Report this Post06-14-2021 08:53 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll see if I can get hi to try once more. As said, he's ready to burn it. I suggested something earlier and he said he's done. I'm just trying to decide if it's easily fixable before I consider buying it. Like the problem with it running on just 4 cylinders. Caused by a loose fuse holder. I would have to stretch finances, but I'm willing to tow it up to you if the price is right and I buy the car.
Report this Post06-15-2021 04:20 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
[/b]
Still say that the problem is most likely electronic. Probably a good scan of the ECM and a check of the wiring at pin C9 as in my post above may pinpoint the problem. Anything is fixable. It just takes time to diagnose and fix. The 4.9L is an excellent engine, strong light and reliable. IMO, the best Cadillac engine ever made.
[This message has been edited by Dennis LaGrua (edited 06-15-2021).]
Report this Post06-15-2021 08:47 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I forwarded your advice on the C9. Let's give it the day to see if he tries it.
[This message has been edited by fierofool (edited 06-15-2021).]
Report this Post06-15-2021 04:16 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dennis, I'm sending you a pic of the ECM connector in your email. C9 is pink. You can see the full color pinout in the photo.
Report this Post06-15-2021 09:58 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
When the ignition is turned on, the SES light comes on briefly as it should. When a scanner is connected, there is no SES light. There is no data displayed on the scanner. This is a SnapOn scanner. The only scanner that will pull any limited data is one that uses a smart phone for display and it doesn't
There is no blue/orange wire in the harness. The pink wire (may be pink/black) at C9 is from the power steering pump according to the schematic and apparently has no power.
Chip numbers are:
BWYJ
1624
2453
Light blue in color.
Should there be a jumper wire in the power steering pump harness connector? With the pump deleted, the harness is just there. If so, it's possible that while working on the car, it has been knocked out at some point. There's none there.
Dennis, PM your phone number, please.
Report this Post06-16-2021 04:15 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Chip numbers are:
BWYJ
1624
2453
Not many scanners work with the Cadillac ECM's. I have an older one that does and will go to the garage tomorrow and let you know which one it is.. Yes the wire at C9 is the power steering power feedback. It must have 12V ignition power applied to it otherwise the ECM falls into limp home mode. It is critical to have power there for ECM function. I believe that is the problem.
Cell number was PM to you a few days ago. I'll resend.
Report this Post06-16-2021 07:45 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe there was a jumper in the power steering harness plug and it became detached while trying to resolve the dead injector bank issue. Should we put a jumper in the PS harness plug? Is that a safe way to do it? It looks like they used E3 to bypass the PS switch, eliminating the blue-orange wire.
I'm leaning toward the likelihood that there was a jumper that became detached while trying to resolve the intermittent injector bank issue. It was during that time that the current problem seemed to rear its ugly head.
Report this Post06-16-2021 03:24 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
E3 is Serial Data In from the BCM.....
87convert
Report this Post06-16-2021 06:53 PM Click Here to See the Profile for 87convertSend a Private Message to 87convertEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an Auto X-Ray 6000mscanner which works for both of my 4.9 installations. One is a 92 Eldo with 2 O2 sensors and the other is an 83 Deville with 1 O2 sensor.
Rolland
Report this Post06-16-2021 10:29 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
This engine is a 92-94 DeVille/Seville. The engine uses a crossover with the downstream O2 sensor disabled. I don't know what scanners he's used, but I know the last one was a higher end SnapOn portable and I don't believe it would read it.
I saw 1 schematic that showed E3 as connected to the power steering pressure switch via a pink wire. The blue/orange wire is absent at C9 and replaced by pink. It does have 12 volt with ignition on.
[This message has been edited by fierofool (edited 06-16-2021).]
Report this Post06-16-2021 11:16 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
BTW, he says there is no BCM in this setup.
A previous scan showed 2 o2 sensors and one is disabled. The engine only has one and is wired for 1. I think that was from a scan done by Raydar.
KissMySSFiero
Total ratings: 111
Report this Post06-17-2021 03:14 PM Click Here to See the Profile for KissMySSFieroSend a Private Message to KissMySSFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a 4.9 with the FieroFactory harness. I had to repair or replace several connectors. Whoever they used to build the harness did a poor job. Several pins lost connection due to poor crimping. Some were hard failures, some were intermittent. It was a headache to complete the swap and get everything running right. I bought it as an unfinished project.
SSFiero@Aol.com
Report this Post06-17-2021 07:55 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I erroneously said that the downstream o2 sensor was disabled. This engine only had 1 o2 sensor from the factory is my understanding.
Total ratings: 463
Report this Post06-18-2021 07:20 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
... The pink wire (may be pink/black) at C9 is from the power steering pump according to the schematic and apparently has no power.
I found the power steering input in the shop manual (I forget which pin, at the moment). I talked with Scott and asked him to check. He told me that there was 12V there. This was a while back.
At one point, Scott had a scanner app that ran through his phone.
It indicated that the ECM (whichever one he was running at the time) was looking for two O2 sensors.
Since it only found the one, it was plugging the "default" in to the other slot. (~450mV) It's not the ideal situation, but it shouldn't be too detrimental. Mine has been running that way for years.
(I had turned on the 2nd O2 sensor when I was messing with the Allante stuff. I ended up removing it, but never disabled it in the tune.)
[This message has been edited by Raydar (edited 06-18-2021).]
Total ratings: 463
Report this Post06-19-2021 02:14 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was poking around and stumbled across this. One of the most concise wiring threads I've seen. Figured it might be useful.
https://www.fiero.nl/forum/Forum2/HTML/098096.html
Report this Post06-20-2021 08:09 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. Roger printed it out for Scott and he has it at the shop.
Spadesluck
Report this Post06-20-2021 10:43 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
You could also just get a new harness made. At this point it couldn't hurt. I just redid my 4.9 harness, it is not overly difficult.
Report this Post06-21-2021 07:59 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's one of the options considered. I have been given the names of 2 possible sources. First, it needs to be scanned with the proper scanner that was described, and if that reveals nothing, then a new harness might be in the future.
racer37
Report this Post06-21-2021 02:38 PM Click Here to See the Profile for racer37Send a Private Message to racer37Edit/Delete MessageReply w/QuoteDirect Link to This Post
I need to chime in here as this is my car. I don't think my frustration level is being accurately conveyed.
When bought the car I was told that it did not have power to 1 set of injectors. That was traced to a questionable fuse block that was added in the power supply wiring for the injectors. From what I understand this car was done by the FF and wired by a "Rocket Surgeon" from Redstone. Not impressed with how this car is wired. Ever since that was repaired the car has not been right. Running rich, not running, not idling, when it runs there is power, no get up and go.
Every wire in the wiring harness has been checked and all check good with a multimeter. Sensors have been checked. ICM has been replaced. Cam sensor replaced. FPR replaced. Spark plugs replaced. ECM changed x2. Fan comes on at temperature. O2 sensor replaced. Fuel pressure steady. Timing set around 12*. Injectors replaced with Bosch Type3. Compression has been checked. Mechanical timing has been checked numerous times. Suspect vacuum lines replaced, no vacuum leaks have been found.
It does not make sense that the car will run and idle with A/B shorted but it will not idle smoothly when jumper is pulled.
I see a lot of check this, check that; everything that has been suggested has been checked and rechecked and then checked again. I also see suggestions of changing this part or that part. I am not replacing anymore parts on a hunch, it needs to be proved to be bad before I will replace it or spend another dime on it.
Spadesluck
Report this Post06-21-2021 11:52 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can understand your frustration for sure, just know we are trying to assist not hinder. Not knowing the condition of your vehicle but trying to make sense of your issues, from my standpoint it looks like something is wrong with the harness. There are plenty of schematics to follow for a 4.9 harness. You could pull yours and go wire by wire........just a thought
Report this Post06-22-2021 07:35 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
In a conversation with Charlie, I asked him about the memcal in the ECU. He said it was blue, indicating to me that it is a reflashed OEM unit.
The OEM memcals do not always respond well to reprogramming.
I would contact Ryan at Sinister, and have him replace the OEM memcals with a modern unit and have him reprogram the ECU.
These are the reasons why I suggest this approach.....
- the harness has been checked with a meter and no issues were found when compared to the schematic
- the engine runs ok with the jumper in, and doesn't with the jumper pulled
- the ECU has been replaced (Was the memcal transferred between the ECU's? Were the ECU three letter codes identical? Were different memcals used?)
Virtually everything else has been tried according to info posted in the thread.
Good luck with finding your ghost in the machine, I do appreciate the frustration these issues can cause.
Report this Post06-24-2021 02:16 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here was my solution for easy prom/memory changes. I used flash memory instead of an eprom. It could be said that the chip on the referenced engine has been corrupted but he already changed ECM's and had no improvement.
IIRC I used 27SF512 flash memory in a Moates ZIF socket with a G1 memory adapter but I'll look all that up tomorrow.
Once again a good scan of the ECM should show if everything is hooked up and running correctly but it won't show bad grounds..
After giving the problem some thought, I'll go with Joes idea that the problem may lie in corruption of the program. I would not reuse the old eprom chip but go with a new Flash Memory chip using the Moates adapter and easy in/out ZIF socket as I did. This completely goes around the old chip, eliminates the process of trying to erase the old prom and reprogramming it while still attached to the memcal board. I always though that this was a sloppy way to reprogram but it does work in some cases.
Additionally check for a solid engine grounds (engine block and chassis), and that the ignition module is mounted with a clean bottom on a perfectly clean plate with conductive heat sink grease.
[This message has been edited by Dennis LaGrua (edited 07-04-2021).]
Mickey_Moose
Total ratings: 145
Report this Post07-06-2021 12:51 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
The MEMCAL programming can easily be verified if it is good or not. Of course you would need a burner and associated hardware.
1 thing you can try is toss in another MEMCAL (with original programming) and see if the scanner will get a reading then. The car will not run unless you have a physical VATS bypass. If someone you know has a burner (there is an adapter needed as well), I can check if I still have the modified code on my at home computer, you can then verify if the code on your is good (although there is a chance it could be different). Either way you can then erase the MEMCAL and reburn it.
Report this Post07-06-2021 07:05 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Someone local has a burner and said he will dig everything out and get a chip to racer37. MM, he has probably all your schematics, provided by several who are active in or reading this thread. It's going to be a couple of weeks because racer is traveling.
I'll have a scanner in hand this weekend that is recommended above by 87convert and known to read the ECM.
Mickey_Moose
Total ratings: 145
Report this Post07-08-2021 07:37 AM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is the BIN file I was running.
I do have a couple different ones, but the differences are in spark advance and tires size correction
I was running a manual transmission, VATS enabled and stock tires sizes. If you have TunerCat (or other you will have to turn off the VATS flag if you don't have the bypass module). I may see if I still have TunerCat laying around and will update it with the change a bit later. There was some changes made to the RPM settings IIRC for manual transmission cars.
Here is the file: https://drive.google.com/fi...4S_/view?usp=sharing
If someone wants to send me a MEMCAL I could burn it as well - however I am in Canada and it would probably be better if you can find someone more local so you don't have to deal with shipping/etc. I have an old OBD1 Auto X-ray scanner that also reads this ECM correctly.
NOTE: you need this to read/burn the MEMCAL - this works just fine as I have burned my MEMCAL many times testing different changes - just make the sure you get a good erase on it first (verify it is blank with the burner): http://www.moates.net/hdr6-...ut-header-p-246.html
NOTE2: your programming may differ, so if you use my file to compare it will fail. 1 setting that is different is all that is needed to fail. You will need a copy of the original file that was used. I know my file is good as I was using them.
Edit: found a file that has the VATS turned off (manual transmission - not sure about the tire size correction ATM, but assume stock tire sizes - I probably had this installed in my car at some point for testing): https://drive.google.com/fi...4Pi/view?usp=sharing
[This message has been edited by Mickey_Moose (edited 07-08-2021).]
Report this Post07-08-2021 08:34 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think the individual who is providing the scanner and was going to burn a new chip is still reading this thread. All your info is foreign to me, but he understands it very well. The car is a manual transmission and I'm pretty sure it has stock tire sizes.
Another problem just popped up. I'm informed that the throttle cable just came loose at the accelerator pedal.
Total ratings: 463
Report this Post07-08-2021 09:36 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
MM, Thanks for the files and info.
I have that MEMCAL adapter around, somewhere, but I decided to solder a socket into the memcal, and go with removable chips instead.
I also use Tunercat. Using the NS1 definition file, but I may have one or two others. (Geez... there are only like seven of them, at least the last time I looked.)
My bin is also set up for a manual trans. Tweaked the idle speed, etc. I also tweaked the DFCO "restore" (incorrectly, as it turns out, but that 's a minor issue) and fixed the "pig rich" issue that everyone used to complain about with the Allante setup.
All I have to do is find my spare MEMCAL, and solder in a socket - same as I did with mine. I think I have everything else I need, handy, except for that. It's around somewhere. Just have to find it, after the move.
I'm using 27SF512s. Erasing has never been an issue, since I don't need to use UV, but I always verify them, anyway.
My left (front) O2 is enabled in my tune. It hasn't caused issues, but then everything else is working okay, so it hasn't been really detrimental. I'm going to turn it off in mine (just to make sure all my hardware is still working) and then turn it off in the one I'm doing for Scott. My tune has already been tweaked for tire diameter - essentially the same as stock Formula.
[This message has been edited by Raydar (edited 07-08-2021).]
Total ratings: 463
Report this Post07-09-2021 10:54 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay... The MEMCAL with the socket soldered in was a no-go. So the reprogrammed chip is also a no-go. (Bringing it with me anyway.)
The MEMCAL w/socket is obviously bad. Don't know exactly how/where, but I'll see if I can salvage it. Ran out of time tonight. (The one I put together for mine, years ago, works fine.)
BUT... It's really a non-issue anyway. The bin I was modifying for Scott's car already has the major change I thought I needed to do. (Deletion of the left/front O2.)
This is the same way that my car and Scott's car are already set up. So the only thing he's losing out on are the removal of VATS (he should already have the module - otherwise it wouldn't run at all), removal of some automatic tranny codes (not a show stopper) and an increased idle speed. (The idle speed is the big deal, IMHO. The 4.9 idles at about 700 RPM. Way too low for a manual.) With all of that said, most of the Fiero Factory manual swaps ran okay on the stock (I think) bin anyway, so it should not be TOO much of an issue.
The good news is that the scanner is already set up to read the Caddy. It'll be coming with me.
lou_dias
Report this Post07-13-2021 01:54 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero Store conversions used to remove the SES light bulb because they'd do no reprogramming.
I had my harness taken apart and labelled back in the day and found some issues.
Definitely had to wire in 12v to the power steering input pin on the PCM. That helped a lot. I think the TPS wires were reversed.
Got a custom burned prom to disable the BCM and pass-key.
I can't seem to kill the motor...but it did recently kill my getrag so I've started a 6-speed swap.
racer37
Report this Post08-28-2021 02:12 AM Click Here to See the Profile for racer37Send a Private Message to racer37Edit/Delete MessageReply w/QuoteDirect Link to This Post
im done with this car: [url=http://www.gafiero.org/bbs/index.php?topic=4720.0][/url]
Report this Post08-29-2021 10:17 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
im done with this car: =http://www.gafiero.org/bbs...ex.php?topic=4720.0]
Sorry to hear that you are throwing in the towel. If the problem is definitely electrical/computer related, this can be solved by going to the Summit/FiTech self tuning, bolt on fuel injection system with a earlier Cadillac 4.1L intake manifold (that used the throttle body injection system). The price is $869-$899 for the entire system and it will support up to 500 HP .
racer37
Report this Post08-30-2021 01:03 AM Click Here to See the Profile for racer37Send a Private Message to racer37Edit/Delete MessageReply w/QuoteDirect Link to This Post
I dont look at it as throwing in the towel, to me it is eliminating a headache.
For 2 years this car has taken up space in my shop and cost me a lot of money in new parts. some made a difference, most not. It is time for it to go
[This message has been edited by racer37 (edited 08-30-2021).]
racer37
Report this Post08-30-2021 01:07 AM Click Here to See the Profile for racer37Send a Private Message to racer37Edit/Delete MessageReply w/QuoteDirect Link to This Post
racer37
Member since Sep 2002
I do appreciate the advice, but as I have explained I am not spending any more money on this car
Report this Post08-30-2021 11:11 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Totally understand the situation but perhaps the FiTech F.I. system can be a solution for the next owner of the car.
