  clutch wont fully disengage
clutch wont fully disengage by fierofrenzy
Started on: 03-02-2016 06:44 AM
Replies: 15 (286 views)
Last post by: jscott1 on 03-06-2016 10:28 PM
fierofrenzy
Report this Post03-02-2016 06:44 AM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey you all....what do you make of this ? my clutch won't fully disengage. When I push the peddal initally down, it seems to work OK. I'll put it in gear, pull away, then loss it to the point where I can't shift the car. I fully bleeded the line with one of those bleeder pump tools, and also did the leverage trick on the clutch arm to get any air out of the slave pump . this is on an 88 Formula. Any suggestions on what I should be looking for will be greatly appreciated. I don't want to replace anything I don't need. Thanks beforehand.
Australian
Report this Post03-02-2016 06:59 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
It will be the seals on slave.
Report this Post03-02-2016 11:26 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is one of the most often mentioned problems in this forum over the last 17 years. The search function here will present you with all the info you'll ever need to know.
fierofrenzy
Report this Post03-02-2016 01:05 PM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
What do you mean by "search function" ?
Report this Post03-02-2016 01:20 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Look for the SEARCH function in the upper right corner of the page. It will allow you to find every thread that has ever been written in this forum on a particular subject.
Report this Post03-02-2016 03:26 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierofrenzy, you have a PM.
fierofrenzy
Report this Post03-02-2016 03:32 PM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Gall.....Thanks alot for the info....I'll check it out
Report this Post03-02-2016 04:04 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You've been a member here for more than nine years and you've never noticed (or used) this button?
robert1234
Report this Post03-02-2016 09:52 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
LOL, Pat, that's funny, but we all are goofy sometimes
ltlfrari
Total ratings: 127
Report this Post03-03-2016 09:12 AM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney sells a slave cylinder rebuild kit. Well worth the effort.
Dave
www.ltlfrari.com
jscott1
Total ratings: 415
Report this Post03-03-2016 10:48 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Although slave cylinders are prone to failure, I've had an equal number of master cylinder failures as well. Check for leakage around the master because those seals can and often do leak. Also if your clutch is disengaging near the floor, Rodney's adjustable banjo can give you a better release. Purists will argue all day long it's not needed in a properly working system, but after 30+ years none of our systems are 100% up to spec and a little adjustment on the banjo can make the system work better.
weaselbeak
Total ratings: 76
Report this Post03-04-2016 05:45 PM Click Here to See the Profile for weaselbeakSend a Private Message to weaselbeakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney Dickman That's all you need to know. My clutch was a constant source of irritation, haven't touched it since.
[This message has been edited by weaselbeak (edited 03-04-2016).]
Report this Post03-04-2016 05:47 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
good catch...
[This message has been edited by Gall757 (edited 03-04-2016).]
fierofrenzy
Report this Post03-06-2016 02:45 PM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok everybody.....Its my slave cylinder. I popped the boot, and man....did a lot of fluid come out. So today I just ordered Rodney D's new cylinder, and can't wait to get it. Now hopefully all the bolts will come lose and the job will go smoothly. Wishfull thinking, huh ?
Report this Post03-06-2016 03:06 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
What a surprise!
It's not the bolts you need to worry about. The challenge can often be trying to disconnect the hydraulic line from the slave.
[This message has been edited by Patrick (edited 03-06-2016).]
jscott1
Total ratings: 415
Report this Post03-06-2016 10:28 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, PB Blaster is your friend.
