  Volvo S60 wheels on a Fiero
Volvo S60 wheels on a Fiero by Bridgetown
Started on: 01-18-2014 10:59 AM
Replies: 8 (572 views)
Last post by: Bloozberry on 01-20-2014 07:00 AM
Bridgetown
Report this Post01-18-2014 10:59 AM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
I saw this add with a GT sitting on Volvo S60 wheels. I think they look really sharp.
http://ontario.kijiji.ca/c-...8-W0QQAdIdZ555729975
I can't find any solid info on bolt pattern and offset. Does anyone know the specs on these Volvo wheels?
[This message has been edited by Bridgetown (edited 01-19-2014).]
Darksyde
Report this Post01-18-2014 11:08 AM Click Here to See the Profile for DarksydeSend a Private Message to DarksydeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe they are 5x108 with a offset of 35-40
Luke
Report this Post01-18-2014 11:35 AM Click Here to See the Profile for LukeClick Here to visit Luke's HomePageSend a Private Message to LukeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've seen the ad a few times and the guy mentions he did a hub conversion with a brembo brake upgrade, all probably from the volvo. He's running a different bolt pattern, unless you get a whole parts car what he did is creative but expensive.
DKcustoms
Report this Post01-19-2014 03:10 PM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those rims look great!
Especially on a black car!
Gonna have to find me those rims and get an adapter...
Bridgetown
Report this Post01-19-2014 05:09 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Specs I've found so far
18x8
5x108
65.1" bore
Et46 mm offset
Looks like you can get the same wheel in 17x8 with the same specs.
http://www.vivaperformance....wheel-bright-silver/
With the high offset running adapters of 19mm (which is said to be the thinnest one should use)
Effectively makes them a +27mm offset. Which is probably why they appear to sit just slightly proud in the pics on the fiero.
wftb
Report this Post01-19-2014 06:50 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
looks like a plastidip job . nice car , like to see it finished .
Bridgetown
Report this Post01-20-2014 12:34 AM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
I emailed the owner.
He said he's not running any adapters on the front, and 7/8" thick on the rear.
I'm assuming because he did a hub conversion on the front.
Sjuice
Report this Post01-20-2014 02:39 AM Click Here to See the Profile for SjuiceClick Here to visit Sjuice's HomePageSend a Private Message to SjuiceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wheels look a good bit like the TSW PANORAMA wheels
http://www.tsw.com/alloy_wheels_panorama.php
Their TANAKA looks similar but slightly dished
http://www.tsw.com/alloy_wheels_tanaka.php
They have a limited selection with a 5x100 bolt pattern and compatible offsets. I just wish the had a more choices for a staggered width/offset set that would work on Fieros. I've been thinking about a set along this style for some time.
Bloozberry
Total ratings: 311
Report this Post01-20-2014 07:00 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Motegi MR116's look pretty close, are available in black or silver, and come in quite a few widths, diameters, and offsets with 5 X 100 bolt pattern.
