I'm re-landscaping my front yard, and I'm looking to install low voltage lighting in front of my house. I'm trying to figure out the name of an electric or gas powered tool that allows you to cut channels into the ground, but I cannot remember what it's called. It's similar to a chain-saw of sorts, but you use it in the ground, and it operates at a slower speed. The telecommunications and power companies use them to dig trenches to lay their cabling.
Is there anything like this that they sell for the consumer that's hand-held? I don't want anything huge, and I'm probably not going to go very deep anyway, but I want to make it as straight as possible because I intend to put all the cabling in conduit as well.
(P.S. I will call the local utilities to flag it out for me before I start digging).
Thanks Fats!!! That's what I was talking about. Do you know if they sell something like a hand-held version? Maybe I just need to not be lazy... but after three days of tearing out everything, and moving several tons of stone, I'm just being a lazy SOB... I didn't see anything at Home Depot, and with the Social Distancing crap... there was no one around to ask. But maybe I just need to dig that **** by hand...
Originally posted by 82-T/A [At Work]: Oh **** ! It's called a trencher... and they have hand-held ones! Awesome! I found it when looking at pictures of Ditch Witches... thanks!
They have hand held ones ? I have never seen one. Link ?
I was going to say look at how a ditch witch works. Looks like a giant chain saw to me. I have not done 12V lighting but the wires/conduit can not be so big that I would rule out using my chain saw with a crap cutting chain.
You'd get about 4' before the dirt and sand caused so much wear and stretch in the chain that it just comes off the bar, not to mention ruining the bar and it's end roller sprocket.
Are you just looking to cover the low voltage line for the lights? Since they are low voltage the lines don't need to be burred. If you want ot bury them for cosmetic reasons just use lawn edger and tuck the line in by hand after. Or if you want it deeper rent a bed sharper and then tuck the lines in. Trenching for low voltage just seems overkill, unless you are just a glutton for punishment.
Thanks guys! Yes... it is low-voltage wiring. I'm trying to do it right, I suppose I could just cover it... but I hate to do things half-assed. If I absolutely don't need to bury it, then I suppose I wont. I'm just looking for the right way to do it.
I do have an axe pick too, thanks MJ... the house came with one in the shed behind the house when I bought it! haha...
LV wiring doesn't need to bury deep and most LV light systems don't want that.
Like olejoedad a flat blade shovel and wait until you have rain to soften the ground.
push in fairly straight. Wiggle handle to open a slit. move to next spot and repeat.
If ground has a lot of rocks or roots might not work well but many trenchers for this job will have problems too...
I have 2 you can have and I never ever want to see them again........
Lived without one when I needed one, now I have a pick and a mattock and will never choose not to have one. The land I am on now, I transplanted 11 smaller trees in a day with a shovel and pruners. Love this place. Depending on the dirt, a skinny shovel may be perfect. I only like long handle shovels, the others will have you bending over too much too often.
Thanks guys.... I've installed the wiring and lights, looks decent. Still have a lot more work to do in the front, but this is good for now. Pea-gravel gets delivered today, and I have to buy some more plants. The plants will have to fill in some more as well, and I need to trim the trees... but it's looking better. I'll take a picture from the street when I'm done.
