It's not leeching or free stuffs. It's just the cost is based on cost recovery.
Course, I could always jump on wish.com and send my money to China for the stuff I want instead of spending it locally. just like what ducked up the economy in the first place.
You of all people should know copying an item ,. someone put time into r&d of the item you plan on JUST making a copy of. is questionable. morals wise You'll need a laser plotter/scanner and software before the printer anyways.
{sarcasm on} so just do what most others do that don't want to pay for things, go shop lift it. as you're doing the same thing with extra steps. j/k ing {sarcasm off}
THAT said. if you saw something and are going to just make your own take on it,. Trying out the 3D printing on a library printer is smart, but be warned you most likely will be like ,"I want one" after using it.
3d printers are neat, only down side is they print very ,very slow, the larger ones are awesome. like a 36"x36" square platter and can print up to 48" tall. The metal 3D printers are even better.
Because they tend to print slowly, and no idea of how large an item/part/piece you plan on printing. you might inquire if the printers power is cut off overnight, (fire hazard) if it is not. you can load your cad file and have it print overnight, If it does, you might have to start the print as soon as they open. and make sure the projected time to print is less than the hours of the library being open. you don't want it stopping before your part/piece/whatever is finished. have fun
[This message has been edited by E.Furgal (edited 02-05-2020).]
Why leach off of your government? Instead of jamming up "free stuffs", move on with your own.
Government controlled library printers? Oh, this should work out quite well...
You've never rented tools? vehicles? BOOKS. maybe a vehicle from a friend because you needed to pick something up and your vehicle can't fit it.? or a tool that will be a one time use and you borrow it from someone OR an automotive parts store instead of buying your own.
Never mind that a PUBLIC library is there to be used by the local population if they are part of the tax base or not (children, retired folks, homemakers/etc).
I think it is damn cool that a library has one to use. To play with/use if your in the market to buy one and want to try one out first or you're never going to buy your own.
I'm sure there will be a back pedaling post at some point if not already. It's your M.O.!!
It's not ending up an exact copy. It's being modified from an existing jig. You know, like modifying a Fiero
Basically it's for scarfing on a sliding miter saw. 15 or 20 degree cuts along the length to splice shorter pieces into one longer stick. The angle isn't really that critical so long as they are all the same.
It was easy to do on my old radial arm saw but I need a jig for this saw to keep my fingers at more or less factory length.
I still haven't decided myself if it should be printed or just make it from plywood. Picture a Stanley square cut down to the right angles and a toggle clamp screwed on top.
It's just something I will be getting a lot of use out of for quite a while.
[This message has been edited by MidEngineManiac (edited 02-05-2020).]
Wouldn't the plywood version be more stable and accurate? In addition, you could make a prototype in a matter of minutes and then make another, better one just as quickly.
Looking at that site makes me want a 3-D printer. I could see it quickly becoming an obsession. I would spend the rest of my days printing truckloads of stuff I don't even need, just because I can. My house would forever smell like burning plastic.
"Where's Willie?"
He's in his basement, printing a submarine.
"Willie doesn't have a basement."
Yes he does, he printed it last week.
[This message has been edited by williegoat (edited 02-05-2020).]
"Where's Willie?"
They are very fun to use. A god send for those with vehicles with plastic parts no one makes, Also great for models you can custom. I hope to soon be printing speaker pods for the cutlass for the kick panel. seatbelt retractor cover with tweeter pod. rear window interior trim with pod for the rear channel of the dash cam. to replace the oem upper trim piece. 3rd brake light housing for bottom of rear window rear deck . mount for modern rear view mirror giving me map lights up front (only two side interior lights between the doors and opra windows) compass and garage door opener . And get the on window oem one gone. A cup holder panel that fit in a spot in the console , that is just a small bowl panel put comes off the top of the unit. behind shifter but before the console storage box/lid
If you want to "get into" 3D printing, now is definitely a good time. the traditional type which melts filament (plastic-y string onna spool) or the SLA resin types (the pieces comes out of a vat of goo)
Some of the resin printers are really good. 200-300 bucks.
SLA (Stereolithography) uses a photo-resin and a laser to build and while it can generally build more detailed prints, is usually way messier and weaker builds.
The GOOD printers are SLS/SLM (Selective Laser Sintering/Melting) which can do some really cool designs and utilize metals, but those are big money ($100k+). FDM is definitely the easiest to get started on. Resolution isn't there but usually you can finish them in pretty well with some post print efforts if you really need it to look better.
